The bad, the good and the ugly Z!
Guest
Posts: n/a
Im planning on purchasing a 93 NA 5spd ZX tomm.
before i do that i wanted to ask your opinions on the Z and any tips on how to buy a healthy Z.
The Z comes with a VG engine, the same one used in a maxima. The 89-94 GXE maxima have exhaust stud broblems. Does the Z have the same problem cause they share the same engine?
Does the Z have VTC failure.
What does NA 5spd Z run in a 1/4 miles??
Any other tips or comments are welcome.
Thank you.
Thank you.
Guest
Posts: n/a
Re: The bad, the good and the ugly Z!
They also don't really share the same engine from what I've learned. Aparently, there are alot of differences. The Infinity J30 is nearly identical engines. The only VTC failure I know of is the springs whicg get bad over time. Really simple to fix ($5) and there are even some upgraded springs that I belive are used to quiet down the system ($18).
Biggest things I'd look for off hand would be fluid leaks and rotor warpage.
'91 300ZX NA 2+2
'89 240SX Coupe
'91 300ZX NA 2+2
'89 240SX Coupe
Guest
Posts: n/a
it cost me $55 for the power steering pressure hose and about 100 for labor but thats b/c they took there sweet as time i guess when mechanics see the car they auto maticaly think we are millionares or something...haha that would be great to bad im just an everyday working man. but yeah thats about it but if you want to realy know it cost about 875 dollars to replace a clutch, slave cylinder, resurfaced flywheel, and a bearing in the driveshaft was replaced so almost a thou for all that but well worth it my car runs like a dream now...
buy the z!
mike
90 3zx2 n/a 2+2
shes a work in progress!
buy the z!
mike
90 3zx2 n/a 2+2
