awww crap.....
Old Jul 7, 2007 | 01:24 AM
awww crap.....*update**
ok, new/er flex and converter is installed, there is still a knock, coming from the #2 piston compression test results are on their way..
Old Jul 7, 2007 | 02:57 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
... why would you pull the engine for that?
Old Jul 7, 2007 | 12:38 PM
for a trans? because i might also go with a manual trans, or i might put a different motor completely in there..
Old Jul 8, 2007 | 12:13 PM
b300z's Avatar
caught the z fever
no need to pull the engine. the tranny does come off.
Old Jul 8, 2007 | 06:39 PM
yup then just drop the converter put up the flywheel etc. dont know how it might be though adding the master and plumbing, you could pull it off im sure, but it will probably be not so fun, but so worth it in the end
Old Jul 9, 2007 | 06:40 AM
if i go manual its getting a wilwood pedal master cyl. and slave cyl. and SS lines all the way around and maybe a bitchin centerforce clutch.
Old Jul 9, 2007 | 09:45 AM
fidanza with ACT on top of it FTW!!!!!
Old Jul 9, 2007 | 01:35 PM
Riz Z Speed's Avatar
Administrative Brown Guy
don't get centerforce. Dunno why they make the Z ones so bad and the domestic ones so mediocre.
RPS, ACT, & JWT make good clutches for the Z.
Old Jul 9, 2007 | 04:24 PM
at a shop my freind used to work at, they installed a fidanza flytwheel on his camaro, it turns out that fidanza machined it wrong and everytime he pressed in the clutch it would pull back on the thrust bearings. and well it only took so long before the thrust bearings gave out, then when he pulled the flywheel out is was majorly warped beyond use, thats why i dont use fidanza's..
i was actually thinking of getting the OS gilken 3 piece clutch.
Old Jul 9, 2007 | 04:26 PM
entropy31's Avatar
The Cake Is A Lie!
wow, how blatantly unnecessary.
Old Jul 9, 2007 | 04:32 PM
yes, but i like going above and beyond with clutches..
Old Jul 9, 2007 | 04:41 PM
entropy31's Avatar
The Cake Is A Lie!
toss in the HKS 6-speed while you're at it.
Old Jul 9, 2007 | 04:44 PM
oh haha, yes i know its a 1200 clutch, but well worth it, even its a stock car..
Old Jul 9, 2007 | 05:09 PM
not worth it, and fidanza is probably the premier pressure plate companies in the world, they should have fully re-funded him, and ive never heard of a single person have a problem with fidanza until now. so one bad experience from your friends camaro leaves you with a grudge on a company? lol, thats not very fair
Old Jul 9, 2007 | 05:12 PM
fidanza makes flywheels snw, plus i dont think a camaro that put 600 to the wheels is shitty, didnt you consider putting a sbc into your 260???
Old Jul 9, 2007 | 06:19 PM
wow, first off my bad, i definatly meant to type flywheels but i just woke up. second, i dont like camaros unless they are the real classics. 70's or older. and the SBC swap in my 260 was when i was getting down and out and i actually saved teh 260 from a guy that was gonna do an SBC swap to it. if i ever wanted to make a straight up drag car though then maybe i would use one.
Old Jul 9, 2007 | 07:33 PM
MikeZ's Avatar
I think the Tomei/Hollinger sequential would be better
Old Jul 9, 2007 | 08:50 PM
Old Jul 10, 2007 | 01:15 PM
MikeZ's Avatar
It's the most rediculous tranny ever made for the Z, I saw it somewhere. I think it was AMZ or something...
It was like $16,000
just in case you were wondering, im joking.
Old Jul 10, 2007 | 03:00 PM
just got quoted $390 for a new factory flex plate today...
Old Jul 10, 2007 | 07:19 PM
Ttt
Ttt
Ttt
Ttt
Old Jul 11, 2007 | 12:14 AM
ok, i lost my list of numbers, but cyl. 1,2,4,6 are all below 150psi.
Old Jul 11, 2007 | 01:22 AM
that kinda stinks, but i think your all right, doubt youll notice it, just take good care of her, maybe a little thicker oil, but then again your in the desert.... at least yours isnt like my Z32 was, 95 psi!!!! lol.
Old Jul 11, 2007 | 01:29 AM
well, i ran my car up and down a mountain (highway 74) doing 50-100MPH and almost never going below 5k RPM, about 8 times plus all the street driving and the trips to the "back strait" for top speed testing its amazing that it still lived for as long as it did..
Velox ZX
Nov 5, 2010 03:52 PM
Carl's Z
Mar 12, 2007 07:19 AM
ThermalWake
Oct 5, 2005 07:56 AM
Skully
Apr 12, 2005 05:13 PM
BackseatZ
May 26, 2002 09:03 PM
