91 dies, sometimes while driving. Help, please
My g/f's 91 NA sometimes dies when driving or when coming to a stop. This only happens when it is pretty cold outside and the engine is not completely warmed up. Once you drive it for a while the problem goes away. I am driving her car now because it scares her. Any help would be great. Kinda broke at the moment so I can't take it to a shop. if it is something i can fix it would be awesome.
Thanks
Stephen
Thanks
Stephen
Clean the MAS and connector, as well as TPS, CAS, and PTU connectors.
And just because it can be a problem without you knowing it, test the resistance across the injector leads - should be 10-14ohms.
I am trying to do the cleaning thing and i assume i have to take the grill off. Is it just the top 2 bolts or are there more. I took out the top 2 and wiggled it but i didn't wanna break anything.
edit: got the grill off. now i can't get the wiring harness off. any help is appreciated.
ok, i cleaned the MAS and barely got it back on before the rain. Now the rain won't stop. It seems to have helped a little. I am going to do all the other stuff when the weather cleans up. I found a great reference page though.
http://www.twinturbo.net/nissan/300z...hesitate2.html
