350z Vs 300zx
Old Jun 18, 2005 | 02:11 PM
  #26
CanyonCarver's Avatar
Jack Of All Trades
Originally Posted by Neochron
Lower compression does allow you to boost an engine easier but you can boost the hell out of a high compression engine. It just really comes down to tuning.
Show us.......
Old Jun 20, 2005 | 09:49 PM
  #27
91zxtt's Avatar
That's it?!? Really?!? All this time I thought it was more complicated than that. I wonder why everyone doesn't boost the hell out out of their cars with higher C/R's.
Old Jun 21, 2005 | 06:08 AM
  #28
Jack Of All Trades
lol............ after a little research, I learned why.
Old Jun 21, 2005 | 10:07 AM
  #29
bardabe's Avatar
Bad Speller
does anyu of the research invole the work "BOOOM!!!"
Old Jun 21, 2005 | 12:29 PM
  #30
Jack Of All Trades
In my readings, I've learned that if you go over 5-6 psi boost on a 10.5:1 c/r engine things like pistons, rods, head gaskets and cranks go boom. Now I know you can build up a bottom end strong enough to handle the pressures associated with higher boost on a 10.5:1 c/r engine, but it gets a little more elaborate when you have to start doweling/pinning your cylinder walls (to keep them round) and O'ringing the block deck and going to bigger head studs to keep from popping the head off.
In my readings and calculations, this is all based around compression pressures. Not so much compression ratio. Compression pressures are determind by your dynamic compression ratio which is determined by your static c/r and the timing of when your intake valves close on the compression stroke. This is a big variable from engine to engine. I did some calcs, and determined that boosting the n/a engine to 5-6 psi creates the equivalent compression pressure as a TT boosting to somewhere around 15 psi, or something like that. Because of other dynamics, you don't get the same performance out of the n/a as you do the tt, even when running the same compression pressures.
Old Jul 9, 2005 | 10:33 AM
  #31
xsciuga's Avatar
z32 is quicker stock, almost a half second quicker..Whoever said you can boost a high compression engine, I have lost mucho respect for you..Tuning dosen't mean **** when you're engine is knocking..If you got 10:5, running 98 octance, I think the safest amount of boost before detonation is 6 psi....There's no Tuning about it, if you go over, the engine can't handle it..Sure you could dump money into a motor that will last, but it will still be damaging it..Forged pistons aren't invincible..Sure they'll take the abuse- for a while..but if you want a car you can drive to the supermarket, you need low compression. I think if one had a 350z, and a 300z and had a budget cap on both of them...300 would turn more heads, be quicker, and probaly handle better. I love the new Z's though, but so out of my price range. Tear.
Old Aug 1, 2005 | 01:24 PM
  #32
sya11's Avatar
i dont have any picz but all i can say is that i have a realy big turbo and it barly fitz stock the turno pulls out about 350 with stock block but if you do what i did itz can push about 600 all together but 550 to the wheels i dont want toblow it .
Old Aug 1, 2005 | 07:24 PM
  #33
91zxtt's Avatar
I'll quote myself from earlier....'Come again.' You have to give more details than that. You bought your car in April of this year, right? If i remember correctly, it was a graduation gift. Then you said you have 875HP, now you're saying 600HP (I'm assuming); which you say leads to 550RWHP.
I'll be the 1st to call BS on this one. That's not even a 10% loss through the drivetrain....no car is that efficient. Start posting some pics or a dyno sheet because none of your stories hold water.
Old Aug 2, 2005 | 08:22 AM
  #34
emo236's Avatar
confuzed member
I'll 2nd that. I call BS until I'm proven otherwise. Also, as far as handling, I don't know about Z33's but Z32's have a tendency to udersteer a little in stock form. This can be fixed to a point by leaving the front shocks in touring mode and the back in sport mode, since the problem is that the front is heavier. Also, you say you have a "really big turbo," what kind? What was involved in a single turbo setup. Joel Grannas did a single turbo conversion with a "really big turbo" and got 540whp at 30psi, so you're SECOND comment is possible. do you have 2 Z's? one with 550whp and another with 875whp?
Old Aug 3, 2005 | 09:42 AM
  #35
sya11's Avatar
i said i have a big turbo that can push out 600 alone custome turbo
Old Aug 3, 2005 | 01:01 PM
  #36
DanZ32's Avatar
Dan's the Man
sya11,
Unfortunately, just stating you have "a big turbo" is not going to make your horse power claims more believable.
Do you have any pictures of your set up?
Are your claims based on dyno runs? and if so, can you post the report?
Can you give us a greater details on your cars set up? Engine wise of course and what have you done trani wise, suspension wise to support that kind of power and transfer it to the road?
If you can't back your claim, you are best to keep it to yourself.
Old Aug 3, 2005 | 01:32 PM
  #37
emo236's Avatar
confuzed member
so what kind of "really big turbo?" What kind of intercooler setup did you go with that setup. How did you go about with the piping? How about some pics of your TT?
Old Aug 3, 2005 | 01:34 PM
  #38
emo236's Avatar
confuzed member
btw guys I have a 4 billion hp car, but I don't have any pics, documentation, or explanations of what I did to it. I did add a custom 40 ft trim Turbo that I made of coffee cans though.
That's just an extreme example of how it can be hard to believe things if there's no backing it up. Back it up and shove it in our faces.
Old Aug 3, 2005 | 02:43 PM
  #39
Riz Z Speed's Avatar
Administrative Brown Guy
im gonna change out the plugs in my car soon....afterwards i should be much much faster than 91zxtt's car after he's done with it.
Admin powers i tell you, Admin powers!
Old Aug 3, 2005 | 04:40 PM
  #40
entropy31's Avatar
The Cake Is A Lie!
d00d i just got done bilding a 7second geo metro baby!!! i took a trubo off the diesel of a train!! its biggewr then the car yo!11!!1111
Old Aug 3, 2005 | 07:10 PM
  #41
b300z's Avatar
caught the z fever
haha
my schwinn scooter hits 200+ mph in under 8 seconds with my 4 roots style blowers and Tornado intake
even the admin powers cant handle that
EDIT: All 4 are attached using duct tape too!!!
Old Aug 3, 2005 | 07:32 PM
  #42
Jack Of All Trades
Nunno you guys can beat my nuke powered zun zled that travelz thru time.
Old Aug 3, 2005 | 07:38 PM
  #43
entropy31's Avatar
The Cake Is A Lie!
well, i gots a magic school bus....... ummm.... this thread needs to be taken out back and shot. what was it originally about?
Old Aug 3, 2005 | 07:39 PM
  #44
b300z's Avatar
caught the z fever
THAMN
its funny
Old Aug 3, 2005 | 07:49 PM
  #45
Ok put up or shut up time sya11.
as for the rest of you, on topic. 300vs350 is the topic as we seem to be reminded, me included.
Old Aug 3, 2005 | 08:55 PM
  #46
91zxtt's Avatar
I guess you guys took my lead and ran with it.
He must be using the turbo that CC discussed in another thread. That one that sits in the spare tire well.
Rizz-
Your car may be faster than mine with those new plugs, but watch out for when I get those zdriver.com stickers. It'll be hella fast. Who cares about twin turbos,...I'll have twin stickers. There's not a dyno on the planet that can measure the power. I hear the Navy secretly uses them to power their entire fleet of ships and planes. Entropy can back me up on this.
Old Aug 3, 2005 | 09:26 PM
  #47
entropy31's Avatar
The Cake Is A Lie!
Rizz-
no way d00d. we had stickers and b16's with NAAAAAAAAAWWWWSSSSSSSS and a BOV that went VRRRROOOOOOOOOMMMMM PSSSSSHHHHHHTTTT. SO COOL!1111!!!1!!1!!
EDIT: thats classified till race warz, so dont go tellin nobody
Old Aug 4, 2005 | 08:28 AM
  #48
emo236's Avatar
confuzed member
Mines bigger than yours! haha. So I prefer a 300zxTT over a 350z, that it until they come out with a 350zTT.
Old Aug 6, 2005 | 02:18 AM
  #49
My Fairlady Z's Avatar
Ruined By Spudz
300zx > 350z(no x because they're gay)
Old Sep 4, 2005 | 12:42 PM
  #50
EddieZed's Avatar
I would think that Nissan would not produce a new line without the foresight to surpass the previous generation. That said I am strongly biased in favor of the Z32. In fact I have driven every day either a datsun 280Z or a 300ZX TT for the last 25 + years. I don't care for the new Z's body style without serious body kit changes so consequently I have anInfiniti G35 coupe. as a daily driver. My 93 300ZX TT is neary at stage V, after a long drivetrain overhaul. Have begun suspension and brake upgrades before I start braking in the new clutch and relearning the car. I remember my first long drive and the sound of the engine was like that of a turbine engine. What A beautiful sound!
