Volk GTS MERCURY SILVER INSTALLED
Originally Posted by b300z
looks good!
i was also going to say something about the height
not bad looking wheels, though i dont think i will ever like that multi piece rivet crap.
glad you went with the T1-Rs instead of some of those other tires you were looking at. i thought you might like them.
get the 300 deg camber kit too if you use the eibachs.
Originally Posted by Murph Z32
How much will eibach springs lower my car? Wouldn't coilovers be a better way to go? I've never lowered a car before and don't want to F this one up.
eibachs will do .8". coilovers are a total waste of money unless you are constantly going to need to re-tune your suspension, like for serious racing. you dont need coilovers.
did the wind carry away your last $100?
The stock springs might be sagging a bit in front. I think you should install the lowering springs and then if the back isn't low enough, take those springs out and cut a half coil off each one to drop another quarter inch.
lets try to take another approach to the suspension problem.
Lets consider money what appears to be the biggest issue a non-issue.
Coil overs give you a wonderful range of adjustability both height, rebound, and dampening.
I myself have 2 sets of springs for mine 10.7kg/mm and 8.6kg/mm front back and again 8.2 front and 6.6 back.
I use the harder ones at the track and the softer ones for daily driving. I raise the car about 1/2 in between the two sets both front and back. dampening levels are adjusted as per needed.
I do not need a camber kit as my alignment at both heights are well within specs.
KYB+Eibach are good solid upgrades for the Z and offer some adjustability.
Now, lets factor in cost again, cause we all aren't made out of money (SPORTBIKEMIKE) so, here are the costs.
Eibach+KYB+camber kit = about 600$ give or take a hundred depending on purchase price/tax/shipping.
I got my coilovers (k-sports) for 895$ as part of a group buy. the second set of springs cost 200$ for a total of 1095$
so, there is the difference, one is 500$ more than the other.
Good point
If you look around
you can pick up a set of FLEX for about 1000$. Cutting springs Isn't a good idea on Eibachs because they are progressive rate. Remember the smaller the movement the stiffer the response. Ever see old Cadilac springs, like 2.5 feet long when not installed.
yeah SPL coilovers look cheap, Specially since they are made by KTS. I mean S-chassis guys tend to avoid them, but if you are looking just to lower the car then you might like them.
BTW my S13 is pretty much sold, and I was looking into some Volk LE37. 19X8.5 +12 and 19X9.5 +22 and I also was looking at my lowering options and I might go with the SPL coilover kit. I have Kei Office Suspension on my S13 so I'll tell you guys if I feel a difference. but then again its a completely different car so I will do my best.
-Juan
-Juan
