vibration at 60mph and up
Old Jan 30, 2006 | 05:11 PM
  #51
Boosted Z's Avatar
Banned
Originally Posted by RodMoyes
Which is why they should A: be BOLTING each wheel to the balancer with a finger adapter, and B: make sure you have "Lug Centric" Lug nuts to make sure that the wheels center on the hub EXACTLY like it does on the balancer... Just having the wrong lug nuts and or a missing or ineffective hub centric ring can cause ALL OF YOUR ISSUES. Does your buddies $3,000.00 machine happen to have a finger adapter? 1 out of about 100 high end tire shops has a good selection of finger adapters and even fewer know how to use them... Just because it zero's out on a machine, doesn't mean it will zero out on the car. THIS IS WHY I ASK. Rod.
well i check on wat u said and got them all balanced again he does the dynamic balnce both sides of the rim and has like a sh*t load of those finger adapters ans they blanced out good when he put them on it so when im dont with my onversion i hope the wheel bearing i just reconlent changed will help ill let you no thats for the advice rod
Old Feb 19, 2006 | 12:34 AM
  #52
Goofyz's Avatar
im not really sure
did anyone else hear that driving over the recommended speeds on a donut ( the spare tire/wheel) will cause driveline problems especially if its on the opposite side of a larger outter diameter wheel like an 18 with 275s on it. Im theorizing that this would cause premature failure of the differential. Maybe that is what happend to your car, maybe not, if someone has actual facts about this please enlighten me. Thanks.
oh and if you friend has a frame lift put it on there and start your car and run it up through 3rd gear see if you have vibration/ and or hear the clunk...this is a good way to eliminate the tires from the equation. If you don't have vibration when car is off ground then it a suspension problem something is shifting or loose or both. if you have bad vibration when car is lifted than its a drivetrain or wheel problem. Next take off back wheels run car again and you can eliminate wheels from the equation. Have fun,let me know what you find. ( im betting you got a bad differential)
Old Feb 19, 2006 | 12:17 PM
  #53
RodMoyes's Avatar
Doesn't post much...
First of all, Running the mini spare can only damage the differential if... You run in it on the rear of the car opposite a tire that is subsatantially taller or shorter (more than 10%) for an extended period of time. Width of the tire or diameter of the wheel itself makes no difference. The only thing that matters is the OVERALL DIAMETER of the wheel/tire combo. You can have a 20 inch wheel with a low profile tire that overall is the exact same "Rolling Radius" as a 16 inch wheel and tire.
This potential damage is caused because one tire needs to complete more revolutions to cover the same distance... so you have one axle turning faster or slower that its counterpart. Again though, this is over an extended period of time. The same "damage" will happen to your diff if you just turn tight circles for a long period of time... the inside wheel will be turning far fewer revolutions that the outer... Understand?
Now, as for lifting the car and running it through the gears to "Eliminate" a tire shake... You HAVE TO REMOVE THE WHEELS FROM THE CAR. An out of round or out of balance wheel/tire will STILL make the whole car shake even if it's off the ground. In fact, it will shake MORE.
Rod.
Old Feb 19, 2006 | 04:56 PM
  #54
Goofyz's Avatar
Hey Rod, thanks
for clearing that differnential question up for me, i think the tire combo of 275/35 r18 is the one with the worst differnce in overall diamiter but im not 100% sure on that, that was why i mentioned that as a possible problem. And hey, you never know if someone was dumb enough (previous owner) to run the spare on the back on a long trip at 70mph+ there is a good chance they would have stressed that differential beyond its engineering limits.
also if you read my last post one more time and pay particular attention to the last couple sentances you will realize i mentioned to take the back wheels off and run the car like that to eliminate the possible wheel problem. Restating what i already said doen't make you right and me wrong it just makes us agree. Have a pleasent day oh, what tires do you reccomend for the z32, im using Bf goodrich G-force t/a KDW-2s and i love em.
Old Feb 19, 2006 | 05:46 PM
  #55
entropy31's Avatar
The Cake Is A Lie!
Yokohama AVS dB S2's. great wet or dry, and quiet too. i love them.
Z1andOnly
Jun 10, 2012 12:26 AM
datdude407
Jan 20, 2011 09:59 AM
rtmorgan
Feb 25, 2009 03:15 PM
domsgarage
Jan 4, 2004 02:45 PM
Ghostz
Dec 1, 2001 11:42 PM
