Upset z driver
Upset z driver
Alright so I finally got my 17 inch wheels on the car 215-45-17 in the front and 235-50-17 in the back, I have a 1990 300 zx Na I have to tell you the car looks bad *** but here is my problem as soon as I tested it it seemed slower and when I was hitting about 70 it just didn't feel right , it felt shaky so I took it back an had everything balanced again same thing, I know I need rotors but it wasn't the steering wheel that was shaking it just doesnt seem thsame as when I was with the stock wheels, now I'm pissed because the is looking like I want it to but not performing better or the same as it used to? Any advise would be appreciated
Z-31 vibration with new 17" wheels
Check the offset may sound funny but that where i would go if you haven"t yet and your rear tires sound like they are taller than the fronts, which can change the angle* that the driveshaft U-joints have been broken into. Also check differential fluid too low or fluid needs flush and new fluid added to specs. I trust you'll find the culprit. Let us know how it works out.
InspirebySD
Apr 20, 2013 05:53 PM
