Hub question
Old Oct 11, 2007 | 12:59 PM
MikeZ's Avatar
Hub question
So as with guys on here, I am lookin' into buying some rims. My freind is selling his, so i think i mighte consider them. They are 18'( alil' big I know), 245 in front, 265 in back... he had some rubbin' on his 2+2, and do you think with these:
http://www.z1motorsports.com/product...oducts_id=2536
5mm, I mighte not have the same prob.
I know spacers are taboo on 300's, but they aren't huge, right...?
Old Oct 11, 2007 | 07:10 PM
b300z's Avatar
caught the z fever
rubbing on what? where? what are the wheels? widths of the wheel, and offset. and the full size of the tire. sounds like the guy got the wrong size tires
Old Oct 15, 2007 | 02:32 PM
MikeZ's Avatar
M-Sports, hyper black
They are, front: 18x7.5 5x100/114.3 48
rear: 18x8.5 5x114.3 35
they rub on the inside shoulder, probably on the fender.
you mighte have seen them before, they are fairly popular I think..:
http://www.nfcperformance.com/msport...1_563_569.html
Old Oct 15, 2007 | 03:05 PM
b300z's Avatar
caught the z fever
full tire sizes?
Old Oct 15, 2007 | 11:07 PM
MikeZ's Avatar
I believe(his) sizes were 245 35's in front, 265 35 in rear?
I am not exactly sure.
Would they fit okay with the right tire would a better question to ask, rather than prove my freind is a dumba$$, I already know that
Old Oct 19, 2007 | 11:16 AM
Riz Z Speed's Avatar
Administrative Brown Guy
Moved to 300ZX (Z32) Brakes, Wheels, Suspension and Chassis
Old Nov 1, 2007 | 12:59 PM
cake872's Avatar
Hey I was wondering the same thing. Cuz I wanna put 18's on my car but still want to hav a reasonable amount of tire there and not hav it rub. 17's are all right but jus don do it. And I mean the sock rims are 16's so if your gonna go bigger might as well do 18's. But will they be fine alowing me to still turn fully without rubbing the guards and still havin a fair bit of rubber on them.
Old Nov 1, 2007 | 03:30 PM
b300z's Avatar
caught the z fever
if youre gonna go big, minus whale go 20s.
depends on the sizes and offsets of the wheels and the tire sizes. find some wheels you like and do some research
Old Nov 1, 2007 | 04:18 PM
thxone's Avatar
Just because you go up in rim size doesn't mean you need to go wider on the tire size unless you are racing the car. The factory width should be more than enough to hold the car on the road and best of all they don't rub. Going up in rim size will make the side wall of the tire shorter and a little stiffer, which should make it feel more stable in the turns with the same width tire as factory.
If it is rubbing in the front...just stick with a 225 factory size or maybe a 235, just shop for a tire with lots of grip....no need for a 245 up front. If it were me...235's up front and 255's out back and not worry about spacers. Just my $.02
Old Nov 1, 2007 | 04:40 PM
b300z's Avatar
caught the z fever
forgot to answer the question...
ive seen lots of people with those wheels and wider tires. you may have a problem with the offset of the front wheels (along with being small)...which may be solved by a different size tire.
is his car lowered?
Old Nov 3, 2007 | 06:34 AM
cake872's Avatar
I heard about 20"s being but on a Z and tought they were full of ****. But hey to every man his own. Na I don wanna go crazy its a sports car. I just like the look tha 18"s give the car. and I'd like to put about 9.5" wheel with on the back. I just wanted to make sure I could fit the 18"s and still have a reasonable amount of tire wall without it rubbing the guard. U dont wanna be ridding on practically no tire an hit a pot hole to ruin your rims.
Old Nov 3, 2007 | 08:58 AM
b300z's Avatar
caught the z fever
youll have about 2 inches of sidewall with an 18" wheel
Old Nov 4, 2007 | 08:49 AM
cake872's Avatar
That sounds just peachy. I cant wait to sit my baby on some nice boys.
Old Nov 4, 2007 | 05:30 PM
MikeZ's Avatar
again it's his 2+2, and it rubbed on his rear wells...
is there a difference in the 2 seater?
Old Nov 4, 2007 | 07:04 PM
b300z's Avatar
caught the z fever
no .......................
Old Nov 5, 2007 | 07:18 AM
cake872's Avatar
Well like the guy was saying earlier your tire size jus probably is to big. Someone did mention that a 2" tire wall should be fine on 18"s.
Niku-Sama
Other Cars
Jun 24, 2011 10:25 PM
domsgarage
Oct 11, 2010 07:44 PM
