bent/bad rotors?
Old Sep 3, 2004 | 02:47 AM
Mousier158's Avatar
bent/bad rotors?
I recently rebuilt all four calipers put steel braided lines and new pads in. i have improved braking capability, however, when i first apply pressure to the brakes (mostly at higher speeds) my brakes, mainly passenger front, shutter and vibrates the car...the only thing that comes to mind is possible rotor problem. Does anyone have some input for me? Also i know the brake system is bled. i bled the whole system somewhere close to 10 times within the last month...so it isnt the problem. Thanks for any help!!
Old Sep 3, 2004 | 02:53 AM
Riz Z Speed's Avatar
Administrative Brown Guy
you put in new pads right?
did you have the rotors cut before you installed the new pads? if not then you more than likely warped the rotor.
Whenever you do brakes you should measure the thickness of the rotors to make sure they have enough left on them to do their job. If the rotors are too thin or will become too thin during the new pads life cycle then they'll warp causing the shaking you're experiencing. It'll also affect your braking performance negatively.
Old Sep 3, 2004 | 02:56 AM
Mousier158's Avatar
thanks Riz! yes i got new pads...but neglected to get the rotors resurface because they looked and felt good. i thought it was rotors i just wanted an experts opinion
Old Sep 3, 2004 | 06:01 AM
CanyonCarver's Avatar
Jack Of All Trades
If you look on the original rotors there is a yellow paint mark by one of the stud holes with a corresponding yellow paint mark on one of the studs.
These should line up. If the paint marks aren't there, or you have aftermarket rotor, the FSM tells you how to measure the runout of the rotors.
It goes something like: install rotor, using a dial indicator, turn rotor and measure runout, if the actually runout exceeds .002", remove rotor and rotate to the next lug hole, re-measure runout. Keep doing this until you find a position where the runout doesn't exceed .002". If this cannot be achieved take the car to a place that can turn the rotors while they're mounted on the car..
This would apply to any situation where you've had the rotors turned and/or replaced.
Old Sep 3, 2004 | 05:49 PM
emo236's Avatar
confuzed member
Hard breaking (checking out your new set-up's capabilities like you did prolly) can cause warped rotors.
Old Sep 3, 2004 | 06:00 PM
lightspeed's Avatar
Southern Speedster
Just a thought...
If you didn't/haven't, CAREFULLY torque the wheels BY HAND. A mis-torqued wheel can give very bizarre vibrations.
91black2+2
Sep 1, 2006 09:02 PM
FreeLanceBum
Apr 16, 2006 03:41 PM
vegas_speedster
Jun 22, 2005 12:36 PM
gamemannn
Jan 2, 2005 12:01 AM
speedgato2
Dec 3, 2003 12:54 PM
