fast blinker
Old Aug 24, 2004 | 06:55 PM
lightspeed's Avatar
Southern Speedster
fast blinker
signal left turn, lights flash normally.
signal right turn, lights occasionally flash 2x normal rate.
All bulbs burn correctly. any ideas?
Old Aug 24, 2004 | 07:06 PM
CanyonCarver's Avatar
Jack Of All Trades
If the bulbs are good and not loose, you might have a loose wire or a wire that rubbed thru the insulation and is rubbing against metal.
Old Aug 24, 2004 | 07:59 PM
b300z's Avatar
caught the z fever
yea i had the turn signals flash unevenly when the hazards were on. i just took them out and put them back in and it fixed it
Old Aug 25, 2004 | 02:11 AM
emo236's Avatar
confuzed member
It means there's a short on one side.
Old Aug 25, 2004 | 05:53 AM
tnkrstoyco's Avatar
Loves Going Topless
Had the same problem, it only happened when the lites were on(h-lites). left flashed fast like a bulb out and the right flashed normal. Had corrision on the contact in the left front, took out cleaned and replaced. it fixed it. Those cars are just too smart it even knew I had the Japanese bulbs still in the tails when I changed to the jspec. Different resistance, showed the Tail warning indicator on the dash.
Old Aug 25, 2004 | 06:57 AM
lightspeed's Avatar
Southern Speedster
I was confused since the behavior is so intermittent. Looks like I'll be check the bulbs. Thanks for the replies.
Old Aug 25, 2004 | 09:05 AM
emo236's Avatar
confuzed member
If it's intermittent, then it's prolly a wire that's grounding itself and shorting the system every now and then.
Old Aug 25, 2004 | 01:33 PM
91zxtt's Avatar
Probably a bad connection. If youo have corrosion in any of the sockets, then it will create different resistance levels and cause the bulbs to blink unevenly.
Old Aug 25, 2004 | 04:33 PM
Jack Of All Trades
http://300zxclub.com/showthread.php?t=23996
11. If the turn signal blinkers blink at a high rate occassionally (usually just on one side), check the ground on the side that is blinking too fast. It can short out and may even cause it to stop blinking. An electrical shop can redo the ground for about $25.
oneadvent
May 28, 2012 07:17 PM
Pipsqueak
May 24, 2012 02:15 AM
falcon125
Apr 13, 2009 02:15 PM
Whitesmoke
Jun 24, 2006 03:41 PM
81 Black L28E
Apr 25, 2005 03:03 PM
