engine painting
engine painting
My project for today is to paint the cam gear covers, air rail, and the part on top of the plenum, and install new spark plugs. Is there anything else I should paint?
my main problem is getting the cam gear covers off. what are some tips/hints on getting it off?
i really wish i still had my electric fan...
You mean the intake valve covers? Those are the black metal blocks that you see between the intake runners of the plenum. If you want to remove them, then you have to remove the plenum. Or, are you talking about the plastic upper timing belt covers which cover the cam sprockets? If so, then pull up the 60k service 'How to' on tt.net. That tells you what you need to do to remove it.
oh...by the way....some f&^$#$ decided to back up into my car and leave
now i have a nice crack on my WW front bumper from the top of it...almost to the nose piece...to where the middle dam starts
happy new years Mo. Fo.
luckily im getting a new one soon
I know rustoleam makes some new plastic paint. Its designed to flex with the plastic surface rather than crack and flake off. I dunno how much haet it can withstand though. You might want to consider powder coating, I dunno how much it would cost. But I would be worth it to do it once and not worry about it.
Yeah guess I should have been more specific...didnt he say he had some metal parts though. Powder coat metal only. My mistake. Avalon racing use to make Carbon fibre timing covers, but i dont know if they still do.
My only prep was a good ole' coat of paint thinner to remove any grease or grime...Don't have any new pics of my freshly painted cover, but you can check out my work on my old one.. www.cardomain.com/id/shibbyjdm DO NOT I repeat DO NOT use it on the metal part where it says "V6 3000 Twin-Cam 24 Valve" it will smear the lettering so you can't read it.
yea thats the only prep work i did on mine
i am still planning on posting pics
ill probably end up changing the color in the future because it doesnt really match my intake, or the ud pulleys i will get
i just taped over the letters so that the "nissan" still matches my body paint, and the other stuff is still silver
yahh I painted the thing thing that says, "NISSAN V6-3000 24 Valve" bloo. as for my cam gear covers this is what I wanna do.
<IMG SRC="http://z1-motorsports.com/imageGallery/album/Z1GrandOpening/z1_19.sized.jpg">
I honestly think It's more agrasive looking.
Originally Posted by 91zxtt
What are the down sides of that, besides dirt being able to get in there?
Likely to happen? ........ NO ........ Possible?.......... YES Is it worth it? :cheers:
