Drivers Side Door wont open with either handle...
Old Mar 28, 2013 | 05:29 PM
Pete DePalma's Avatar
Ok, I could use some help on this one! I just got done rebuilding a 1990 NA and had keyless entry installed about a month ago and since the actuator is new and I hear it triggering I am assuming it is a matter of a plastic clip on the assembly rods within the door.
Since I cannot open the door from the inside or from the outside it means I cant get the door panel off to see what is going on in there.
I did lift the upper lip of the door panel and pop it off from the top of the door frame and removed the pillar cover to get very limited access and can see the door latch and some of the assembly rods.
I was wondering if any of you have dealt with the door being closed and the door handles not opening the door and could offer some insight or tips on getting the door open.
Your help would be hugely appreciated!
Utah Hawkeye
Jul 19, 2012 07:30 PM
3XAZOWNER
May 12, 2008 07:11 PM
1982zxt
Jan 6, 2006 09:53 AM
B1nAryVilE
Jan 2, 2005 12:03 PM
kewlcat
Oct 26, 2001 09:36 AM
