Z31 turbo help?
Old Oct 31, 2012 | 11:05 AM
slidestatus's Avatar
Z31 turbo help?
so y buddy has a z31 n/a to turbo conversion (vg30e) and is having a little bit off a problem with it. it runs and idles fine... but when he gives it gas it goes up quick to about 3k and then starts bogging down. its been doing this since he started messing with it so we went through and replaced a few things.. at first it seemed to be a fuel problem so he went out and got a walboro 255lp and new 440cc injectors.. installed them and is still having the same problem. we also change the mass air flow and nothing has changed.. just running out of ideas of what it could be.. but it really only seems to do it when it hits boost.
any tips are helpful thanks
Old Oct 31, 2012 | 11:11 AM
also its obviously running rich.. but would that cause it to bog down at higher rpms?...
Old Oct 31, 2012 | 11:27 AM
What ecu / tune is he running to accept 440cc injectors?
Old Oct 31, 2012 | 11:32 AM
just a stock turbo ecu
Old Oct 31, 2012 | 11:43 AM
The stock ecu cannot compensate for larger injectors... especially ones dumping DOUBLE the fuel...
Put the stock injectors back in, and check the ecu codes.
rogerz's Avatar
Grumpy & Helpful
what boost are you running? what is the fuel pressure? Some info besides it doesn't run might be helpful
Old Oct 31, 2012 | 11:46 AM
7lbs of boost... on a stock turbo and 37 for fuel pressure.. we were thinking we may have to actually replace the fuel pressure regulator.. could it be clogged? and would it cause it to bog like that.. im knew to z cars so i dont know alot about how they tick as much.
Old Oct 31, 2012 | 11:47 AM
we ran a diagnostics and we got a read for the chts.. aswell.
Old Oct 31, 2012 | 01:56 PM
rogerz's Avatar
Grumpy & Helpful
the ecu codes are seldom helpful but in the case of the CHTS just replace it. Did you run a line from the manifold to the FPR. the pressure on the fuel ring should rise with increased boost. My 86 T has 20 psi at 20 in HG. It rises to approximately 44 in full boost of 10 psi. and yes the injectors are way to big for your setup. You can't just slap parts on something without a basic knowledge of how the system works. you did I hope check for vacuum leaks which are the bane of the FI engine.
Old Nov 1, 2012 | 01:21 AM
AZ-ZBum's Avatar
Well there's your first problem....
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
Spyder Z 15
Aug 20, 2008 12:28 PM
johnsonsz31tt
May 7, 2008 07:27 PM
thunderz
Feb 12, 2006 06:46 PM
teamadidas
Jun 2, 2005 04:41 PM
