what is the correct timing with the pathfinder distributor ??
Old Aug 4, 2006 | 08:41 AM
ern's Avatar
ern
OK I hope somebody can help me with this. What is the correct timing with the pathy distributor? I believe stock is 15 degrees however when I set this the idle rpms is about 1200. When I adjust the distributor to lower the rpms, the bolt does not match up to the block.
Old Aug 7, 2006 | 06:09 PM
johnZboy's Avatar
Distinquished Guest
Timing is no different. They're both vg30 distributors, just shaped a little different. Your increased idle speed is due to a vacuum leak, I'd bet.
You don't adjust idle speed with timing. Timing will change the idle speed, but, you don't use it for that purpose. Go find the vacuum leak.
Old Aug 8, 2006 | 07:01 AM
ern's Avatar
ern
Ok thanks for the help. With the pathy manifold, I do believe the AACV line is a vacuum line and I ran it to the tubing leading from the air filter to the turbo....I'm not too sure what the purpose of this would be? but this is how it was set up on a '95 pathfinder...... should I have plug this instead.
Jason280ZX
Jan 10, 2014 07:03 PM
7d82adz
Aug 27, 2013 02:21 PM
Flacster
FS: 300ZX (84-89)
Sep 1, 2011 02:30 AM
SneezinPathy
Mar 17, 2010 08:18 AM
nis88300zx
Jul 10, 2005 08:35 PM
