VG33ET Oil Pick Up Tube Help
Old May 11, 2011 | 02:14 AM
Flacster's Avatar
Anyone know what modification is needed to the oil pickup tube to work with the VG30ET oil pan? Im not understanding what it says in this write up. http://www.zfighterperformance.com/VG33.htm Thanks in advance.
Old May 11, 2011 | 06:57 AM
You have to cut the part where it interferes and weld up a new piece to the correct position. TBH though, I wouldn't even bother with the stock vg33 oil pump and just swap cranks and oil pumps with a vg30. Or use the vg30dett oil pump and crank and do a little modification to the block.
Old May 11, 2011 | 06:59 PM
Flacster's Avatar
I thought this option would be easier *sigh* I guess ill pull out the vg30 crank then...
Old May 11, 2011 | 08:07 PM
AZ-ZBum's Avatar
The way I read it, if you use the VG30 oil pump, you can use the VG30 oil pan so you can use the VG30 tube.
Old May 11, 2011 | 08:14 PM
illldeca's Avatar
If you find out what needs to be welded an how i can do it. Im a certified welder i work in a machine shop as a tig/mig welder.
~KnuckleDuster~
Mar 4, 2014 09:14 PM
tamug92
May 13, 2013 11:05 AM
Flacster
24
Dec 19, 2012 02:52 PM
Flacster
26
Nov 25, 2011 11:54 AM
Lanoi
Apr 6, 2010 06:45 AM
