Unknown battery wire on 1987 300zx
The wire in question is attached to the positive cable. As was the case for my car, it probably went to a high-draw source such as an audio amplifier. I would remove it.
Um, that is the positive cable that wire is on. Please don't ground the positive terminal of the battery. Also, if you do connect the positive battery cable, keep the cut wire away from any metal. Fireworks are for the 4th of July.
