Twincharging Might be an Option
*disclaim*This is all on paper, brain, and theory, for personal learning purposes. dont hate. move this thread if needed, or link me to similar discussions please.*disclaim*
Driving an 86 turbo(stock turbo, full 3" exhaust), and find myself bored between 2000 and 3700 RPM(until the turbo spools).
I want a quicker response from the throttle, and being an owner of an 02 xterra, my idea of a quick throttle response can be attained with the addition of a supercharger. My theory is to rig a supercharger small enough to fit near the belts(independently mounted from the engine), and also assist me with a quicker response at lower RPMs.
Obviously, i aim to make this a sequentially twin charged system (super at low and turbo at high rpm). The reason being, i most likely dont have room for a sequential turbo system(a little powered big turbo), although, with an intercooled twincharged system i may not have room either way.
I know it seems to be a taxing labor for quick response, which is why this is all for personal reference. All of the research ive done has led me in circles. Maybe its not possible to twin charge the VG30ET with efficient results (i refuse to mount a roots type system onto a VG30ET(BLASPHEMY!!), and any independently mounted supercharger is built and spools/boosts around the same rpm range as a turbo).
Hopeless? Any links or info or schematics will help. Im not planning on doing this to my turbo anytime soon. but its good to know ya know?
i also saw this and was inspired:
http://www.wheelsjamaicahost.com/whe...?topic=19746.0
Will my addition of another pulley negate the boost coming from the supercharger at lower RPMs? And also consider the lag from the intercooler as well, when ill be running a stock turbo.
Upgrade to a modern turbo and you can have it all. Tod K is running a custom GT35R on his L28 at around the 600HP mark IIRC with no lag. If you're running the stock turbo you're about 30 years behind in technology.
lmao
yeah my turbo is definately dated. but i have a feeling that even with a newer turbo, i might have trouble pickin up momentum off-the-line.
what is an equivalent in size to my stock turbo compared to a newer one like something from jwt while remaining non intercooled? and once i do get a newer turbo, and i want more boost in the low rpm range, would a root type supercharger suffice if i did not mount it directly to the engine? surely there is a way to connect a belt driven roots or twinscrew to some sort of pipe dinger with an electro-mag clutch pulley and a one way valve, into the rest of the intake(now im just guessing what i could do).
anyway, back to reality. help me out on deciding on a turbo dude!. today, my stock turbo pushed between 5-6psi while between 42 and 58 hundred rpm (using an aftermarket analog gague), ad i do not utilize a boost controller. i try my best not to hit the rev limit(the shift **** starts to vibrate, and by habit, i shift).
once i do get a new turbo, should i settle for a manual boost controller? i kinda wanna keep it low tech as to not run the battery, but i could use the information an electronic or an oldschool fuzzy controller would provide.
any help?
any help?
any help?
any help?
Also, ive heard that messing with ported throttles isnt a good idea either, because VGs were built in certain ways to handle certain applications, and any changes involving changing the actual engine will most be good, yet, at the same time mor elikely to destroy your VG. I dont want to over-mod my Z, i just want enough low end punch to k.o. the ricers in Reno off the light. im tired of their welded exhausts, mesh grills with a ghost-type intercooler(theyre invisible!!), or even worse 3 inch diameter exhausts with no sounds of turbos spooling(lag bag)... sound like friggen airplanes.
a t25 is a bit small for my taste, 2 of my buddies run 2 t25's in their twin turbos(one supra and the other a Vr4). but i guess with a bigger intake and a gutted plenum, my response time would kill.
all this info is good, but i also need to know whats in my car now.
a 60mm TB compared to a stcok turbo's what... 55mm? 2.5 inch pipe from turbo to throttle body from what 2"flat? and going from stock to 60 invloves porting right? how do i get this done in a clean fashion?
and ive never heard of supersplit pipes but i looked into it and it seems like a good thing to have maybe? whats on my car now and how is it different or worth getting?
thansk for the awsomeness guys! lookin forward to learning more from everyone. but lets try to swing this back into twincharging...
any help?
any help?
If you are worried about spool time then you should be using an electronic boost controller. With a mechanical one you are starting to waste exhaust before you come up to full boost adding delay to your spool up.
If you are going to go down the electronic boost controller road you may as well go with a Mega Squirt setup and replace your out dated ECU as well and have full control over your engine management. Mega Squirt cost the same as most entry level electronic boost controllers yet has sooooo much flexibility in getting every last HP of performance out of your car.
Here is a stock DP (granted it's connected the z31 turbo is on a l28 manifold)
Compared to a super split or divorced down pipe.
A downpipe is a pipe that directs the exhaust gas from the turbo into the exhaust.
hey cmon now
its an honor to see a-z zbum in my thread!!! but i dont want people in here that are just gonna correct everyone and be a smart-a$$... dont start arguing over names of parts, you should argue over whats better for what applications and bring proof so i can learn too. im the biggest dummy in the thread so nobody should be talking down to anyone or correcting anyone but me.
i know what a downpipe is. and now i know what a split DP is. and also i realize what hoov says about a mandrel bent TB pipe, mine looks like 2 half pipes wleded together.
i wanna hit up pik n pull for another turbo plenum to gut and port. id rather have the ability to swap between the 2... just in case. but ive heard once you make the switch youll never want to go back.
so its mostly just about air flow then... right? and then configuring the ECU to use the new larger volumes of airflow?
where can i get my hands on a twin scroll turbo? id like to go compound turbo, but thats a whole lot of math and welding and money and engine space. (do note that my AC compressor is crap and im gonna take it out for more room, ive already removed the CC or "automatic speed controller" lol). but i do want to keep the power steering... i love power steering.
idk. i anyone has a spare turbo plenum for sale or even better, a used gutted one for cheap... lemme know. id gladly come and pick it up form you if youre around the state of nevada(arizona texas cali), i love driving so...
there arent many turbo 300zx's out here in reno, thyre all NA's that think theyre fast with their welded exhausts and no turbos. some guy even posted on craigslist a "shiro special"... too bad it was silver and an automatic with a terribly torn up interior.
i just want to stand out from the crowd... and with a z31 (probably the only true z31 turbo in a 10 mile radius), i already do. but you can stick out like a roaring fearsome beast... or a sore thumb(my z).
just weighing the options, i dont want to commit and then back out after 2 years of hard work, so i have to do a whole ton of brainstorming before i even have the cash to do so..
if you guys know anyone who compound charges, or twincharges their VG30et direct them here. i dont wanna hear about marc form boost logic(im too jealous of him and mad that he uses a 2jz). i never said i wanted to and i dont care for twin turbo's on my Z either, parallel twins are over-rated.
And as far as I know, no one makes a replacement O2 elbow for the Z31. Plenty of people have made their own split systems. http://z31.com/mods/turbo/wastegate/
Ricer stores. Nah. Just kidding. A good performance shop will be able to source one for you. Just be aware that they are not going to be cheap.
Figure a good (i.e. non-ebay) turbo will run you around $500. More for a twin scroll. And then a good supercharger will be another $500 to $1000. Plus all the custom intake piping and mounting hardware, figure around $2000 in parts alone. And if you aren't a capable mechanic or welder, you're looking at another $1000 to $2000 easily in labor costs. And then, if you're trying for more than 300bhp, don't forget to source injectors, new ECU, and new exhaust. So another $1500 to $2000. So now you're in it for at least $5k. Then there's the tuning aspect of getting that ECU to match the injectors properly and give you the best performance. So that's dyno time. And of course, everything costs more than you think it will, so budget at least half as much more. So budget of $7500 and hope you don't go over.
But honestly, what are your power goals?
And because if you ask either of the two exhaust companies selling exhausts for a turbo Z31 (MSA and CMPerformanceExhaust) for a 3" down pipe, they'll send you the pipe that runs from the O2 elbow to the cat. That's why. http://www.cmperformanceexhaust.com/...-systems/z-124
And don't worry "SoNotaMechanic" Me and Az-bum has called each other enough names to make any elementary school student jealous.
I wasn't going to suggest any power levels for him, just super quick spool time and simplicity. If he indeed does go with a BB t25 or BB t28 he should have enough turbo to support probably 250WHP or so safely if everything else is in place.
i cant apply for a lost title.
how do i lien it to myself? do i biff up an affidavit saying it was towed? or do i get it towed and purchase it from the tow yard? or should i ask my buddies if they know somebody who can fill out the bussiness end of the paperwork?
i live in NV, and the VIN report didnt have any "brands" on it (not reported stolen or missing or damaged), and also indicated that it was last registered in Washington in 2008 (but not by who).
With having just the car and no proper papers stating my ownership or having paid for it (minus the incorrectly filled bill of sale), what are my options?
cuz at the time i was like "omg! an 86 300zx turbo! even if i dont get the title id only be $700 in the hole!"
and now im all like, "man im $700 in the hole"
but seriously, clean vin, functioning engine... with $700+ worth in exhaust, and suspension...
Don't even tell them that. Just get the lien sale paper work. All you need is a bill of sale. if you KNOW it's not stolen, then I wouldn't even bother with that and take a bill of sale down to the DMV and apply for a lost title. It should cost less then $50 either way. I have lien sales many cars and the most I had to pay was $100 and it has back registration.
