Turbo my N/A motor? (Automatic)
Old Jun 22, 2013 | 04:05 AM
Evan Faris's Avatar
Just wondering if it's ok to slap a turbo on my N/A motor after a hefty rebuild one day?
Old Jun 22, 2013 | 07:56 AM
260zturbo's Avatar
Stupid Hurricanes...
Sure you can. Alot of people slap turbos on n/a motors. Just dont expect the auto tranny to hold up.
Old Jun 22, 2013 | 03:53 PM
Evan Faris's Avatar
Why is that? What would I do with the trans then?
Old Jun 22, 2013 | 05:19 PM
260zturbo's Avatar
ZBUM's New Nissan Z31 300ZX Homepage
Jason's Z Site - RedZ31.Com REDZ31.NET JASONBUTTS.COM
"All automatic Z31s used the 4N71B transmission. Change the fluid every so often, and check the level every time you change your engine oil. Also, if you overheat your car for whatever reason and it has an automatic, CHANGE THE TRANSMISSION FLUID IMMEDIATELY!!! If you don't, your transmission will blow up as a result of the fluid getting overheated in the cooler and burning inside the transmission, and this is bad. Of course, you could avoid this by putting in a manual transmission, and have more power and economy to boot! The overdrive switch in the automatics has a temperature sensor that does not allow the transmission to shift into overdrive until it is sufficiently warmed up to avoid possible damage. Level 10 makes an upgrade that will allow your transmission to hold 500+ hp. " quote the almighty zbum
Do what ever you want with the trans.
Old Jun 22, 2013 | 07:15 PM
Evan Faris's Avatar
Thanks for the heads up. I'm probably better off putting in a 5 spd turbo Z engine in then? Do they bolt up the same? So basically all i'd need to do is convert the car into a 5 spd? Btw, my car did overheat awhile back and never changed the fluid. Ugh.. Such expensive cars, but oh so worth it.
Old Jun 23, 2013 | 05:59 AM
AZ-ZBum's Avatar
You didn't actually read those links, did you?
GO READ THIS ENTIRELY:
TURBO TURBO TURBO
johnsonsz31tt
May 7, 2008 07:27 PM
81s280zx
14
Oct 7, 2005 10:48 AM
davidjoe007
Jun 13, 2005 02:34 PM
tay-fu300zxtt
Jun 3, 2005 08:17 PM
rngrck
Sep 20, 2002 06:02 PM
