trans swap
Old Mar 25, 2011 | 10:27 AM
pats84z's Avatar
Question trans swap
hey new member here. im brainstorming about putting a 6 spd trans in my 84. any ideas on what would fit. we have a club in charleston but no one has thought about what i want to do before so they are clueless.
Old Mar 25, 2011 | 10:40 AM
Welcome to ZDriver!
Things you should consider first:
-The 6speed will have different gear ratios.
-The 6speed will have different bell housing.
-The 6speed will have different size specs which will make fitting a biotch.
-The 6speed will have different output splines, so custom drive shaft needed.
And after all that, unless you daily drive on a rural freeway that has 80mph+ speed limits, you'll never need 6th gear.
But alas, if you have tons of money, and awesome fab skills, get to it!
Old Mar 25, 2011 | 10:44 AM
pats84z's Avatar
i was also looking at the skyline r34 engine and drivetrain swap. i just dont know which one i want
Old Mar 25, 2011 | 11:01 AM
Sounds like you have about $10k to blow?
Old Mar 25, 2011 | 11:04 AM
pats84z's Avatar
is there any 6 spd thatll bolt up to the 3.0L
Old Mar 25, 2011 | 11:08 AM
I highly doubt it... since I don't think "6 speeds" even existed in the normal car market when the Z31 was designed in the 80's.
I searched the google machine for ya...
Good read (ZBum is always direct and to the point ): http://z31.com/phpBB3/viewtopic.php?f=7&t=9367
Old Mar 25, 2011 | 12:35 PM
pats84z's Avatar
did some research will a z32 twin turbo motor and trans bolt up in the z31. i know i would have to do some mods but would it be worth it
Old Mar 25, 2011 | 03:30 PM
260zturbo's Avatar
Stupid Hurricanes...
stock no, highly modify with some serious hp then yes.
Old Mar 25, 2011 | 08:21 PM
AZ-ZBum's Avatar
Why would you want to?
SHADY280
Nov 19, 2013 07:21 PM
drfrankenstein
Mar 31, 2007 09:57 AM
SAMZMAN
Nov 23, 2005 09:21 PM
blueyedwolf71
Oct 19, 2005 08:57 AM
White99GSX
May 29, 2002 04:30 PM
