Searching for Short throw shifter 84 300ZX
Old Jun 24, 2008 | 08:50 AM
hjwarrior's Avatar
Hello Everyone,
I have a 1984 50th Anniversary 300ZX and the shifter is going out. It tends to grab in certain gears (2nd & 4th) when the clutch is engaged it does not want to come out of gear. As well, I have a hard time getting it into those gears, it slightly grinds. So my local Nissan dealership told me that the inner workings of the shifter has gone bad and I need a replacement. I am looking for a replacement SHORT THORW SHIFTER, but having an extremely difficult time finding one to match this vehicle. I have gotten different info on what may or may not fit. The Z has a V-6 3.0 Turbo with a manual tranny of coarse. Your help would be greatly appreciated. Thanks
Old Jun 24, 2008 | 09:14 AM
Welcome to ZDriver!
A short throw shifter won't solve a gear grinding problem. If the hydraulic system & clutch are both working correctly, and it's still grinding, the syncros are shot, which means you get to rebuild your tranny, which means lots of $$$ and fun times.
Old Jun 24, 2008 | 11:18 AM
jtz31ae's Avatar
Agreed. It doesn't sound like a short shifter will solve synchro issues.
Mine has always had a finicky 1st-to-2nd shift. It's not much of an issue since I started using Mobil1 synthetic dexron. The old T5 seems to like that better than gearoil or the 50:50 dexron:gearoil mix I used to use.
Old Jun 24, 2008 | 04:37 PM
hjwarrior's Avatar
Originally Posted by hjwarrior
Hello Everyone,
Thank you for the reposes- AGREED THE TRANNY IS SHOT The syncro is clearly having issues!! I will be purchasing a rebuilt transmission. But I am still have issues with the shifter, unless you feel the shifter is not an issue. (But please keep in mind I was having the shifter issue, not disengaging prior to the this syncro issue with the tranny). So I am still in need of help finding a short throw shifter, many thanks for any info you have.
Old Jun 24, 2008 | 06:07 PM
Since it's an 84 Turbo, it has the Borg Warner T5 transmission. Search the web for "Borg Warner T5 short throw shifter."
Old Jun 24, 2008 | 07:01 PM
jtz31ae's Avatar
You can start with eBay:
http://motors.desc.shop.ebay.com/ite...sZ6000QQ_sopZ1
Old Jun 25, 2008 | 07:54 AM
hjwarrior's Avatar
Thanks everyone for your help!!
Old Jun 25, 2008 | 05:21 PM
AZ-ZBum's Avatar
Which idiots are giving you bad information on what shifter fits?
PredatorZ
Jan 8, 2012 09:16 AM
TeamRonin
Dec 16, 2010 10:07 AM
$jared88Z$
Aug 6, 2007 07:23 AM
one_fast_300zx
Oct 20, 2006 06:41 PM
melloyello
Jan 8, 2006 02:15 AM
