really weird clutch problem
Old Apr 20, 2005 | 11:24 AM
300zx nw's Avatar
i got a 300zx a few nights ago went home car ran fine, the next morning i got in the car and it goes into gear with out pushing the clutch in and the car will not move. then it does not stall when clutch is up. and it idles normally. i put fluid in the clutch master cylinder but that didnt do anything could i need a new clutch or a new slave cylinder? can somebody help me with this please??
Old Apr 20, 2005 | 01:45 PM
entropy31's Avatar
The Cake Is A Lie!
get a new clutch. if it was the master cylinder or a lack of fluid it would stall when you let the pedal out and wouldnt even go into gear without stalling. not really a wierd problem, your clutch is made of a material similar to your brakes, and will wear out over time. the less you slip the clutch (like on hills) the longer it should last. but like brakes, it will eventually wear out.
Old Apr 20, 2005 | 03:17 PM
300zx nw's Avatar
I understand, however a clutch usually wears out over time. I turned the car off, and about a hour later i went to go start it and go, the car si,ply did not move. Its like the clutch pedal as pressed to the floor though its not.
Old Apr 20, 2005 | 11:41 PM
300zx nw's Avatar
the shifter is just moving. the clutch doesnt do anything. I jacked the car up too day and when i push the clutch in the wire moves properly and everything but i can just put it into any gear with out pushing the clutch in. and i have pressure in the clutch. but when it is in gear i can rev it to 7000 rpms and the car does not move. i took the shifter apart and i watched the driveshaft and i tryed to move. when i rev it and its in gear or not in gear the driveshaft does not move at all.
Old Apr 21, 2005 | 12:20 AM
entropy31's Avatar
The Cake Is A Lie!
sounds like for some reason the clutch plate is not engaging the flywheel, if it did, the car would not go into gear without the pedal depressed, and most certainly would not rev to 7000rpm standing still. this would not be a hydraulic problem. get a clutch kit and put it in and i bet your problem will be solved.
Jennings.brent6
May 30, 2014 11:10 PM
MadZ420
24
Mar 7, 2009 10:05 AM
300zx nw
May 12, 2005 04:31 AM
300zx nw
18
May 1, 2005 10:02 PM
300zx nw
350Z Performance / Technical
Apr 20, 2005 11:23 AM
