really weird clutch problem
Old Apr 20, 2005 | 11:22 AM
300zx nw's Avatar
i got a 300zx a few nights ago went home car ran fine, the next morning i got in the car and it goes into gear with out pushing the clutch in and the car will not move. then it does not stall when clutch is up. and it idles normally. i put fluid in the clutch master cylinder but that didnt do anything could i need a new clutch or a new slave cylinder? can somebody help me with this please??
Old Apr 20, 2005 | 11:42 AM
bardabe's Avatar
Bad Speller
slave cylinder = gear not going in and stalling.
clutch = bad = no stall and gear going in.
Im sorry but ure gonna need a new clutch buddy.
Old Apr 20, 2005 | 01:31 PM
300zx nw's Avatar
ok thanks well i already bought the slave cylinder. cause it was only $30. so i need a new clutch now. do u think i need a whole new clutcj kit or just a certain piece?
Old Apr 20, 2005 | 02:38 PM
Fast240Z's Avatar
because it's fairly cheap for the whole clutch kit (pressure plate, throw out bearing, clutch disc, alignment tool), I'd recommend that you replace them all, that way you don't have to worry about the other parts falling apart.
Old Apr 20, 2005 | 03:29 PM
b300z's Avatar
caught the z fever
do you feel the clutch engage, or is the shifter just moving?
Old Apr 20, 2005 | 03:47 PM
Z_WRECKER's Avatar
sounds like a clutch to me....did you do burnouts and such
Old Apr 20, 2005 | 05:53 PM
bardabe's Avatar
Bad Speller
a Z's clutch is practically imortal. well mine was atleast so I wonder how the hell your's went out. I pushed my Z tot he limit most of the time I had home made slicks. andmy clutch was fine. U might consider a flywheel as well while ure at it.
Old Apr 20, 2005 | 07:04 PM
Z_WRECKER's Avatar
Once you put any horsepower to the car, stock (oem type) clutch is just plain gone, not to mention if you drive it hard. Clutch will last you a long time if you can drive, rev match, don't ride it, and yada yada yada, but sooner or later it will give out. It's like tires, it wears out... I am yet to see a clutch that is imortal
Old Apr 20, 2005 | 11:39 PM
300zx nw's Avatar
the shifter is just moving. the clutch doesnt do anything. I jacked the car up too day and when i push the clutch in the wire moves properly and everything but i can just put it into any gear with out pushing the clutch in. and i have pressure in the clutch. but when it is in gear i can rev it to 7000 rpms and the car does not move. i took the shifter apart and i watched the driveshaft and i tryed to move. when i rev it and its in gear or not in gear the driveshaft does not move at all.
Old Apr 21, 2005 | 12:31 AM
entropy31's Avatar
The Cake Is A Lie!
sounds like for some reason the clutch plate is not engaging the flywheel, if it did, the car would not go into gear without the pedal depressed (without some nasty noises and smells and tranny bits grinding themselves to hell), and most certainly would not rev to 7000rpm in gear standing still. that would also cause the driveshaft not to move. this would not be a hydraulic problem. everything will still look like it is working properly because it is. the problem has nothing to do with the slave cylinder, master cylinder, wires or anything else like that. get a clutch kit and put it in and i bet your problem will be solved.
Old Apr 21, 2005 | 12:37 AM
entropy31's Avatar
The Cake Is A Lie!
also, it sounds like this link might be something you should check out.
Old Apr 21, 2005 | 07:48 AM
300zx nw's Avatar
ok so do you think i should get a whole new clutch kit or should i get a new fly whell and clutch plate?
Old Apr 21, 2005 | 07:59 AM
300zx nw's Avatar
some one told it could have something to do with the release fork . could that have an effect on it?
Old Apr 21, 2005 | 08:15 AM
300zx nw's Avatar
what cause the clutch plate to touch the flywheel?
Old Apr 22, 2005 | 08:49 PM
91zxtt's Avatar
I think you're on to something with that. A clutch wouldn't work fine one day and not work at all the next, unless you beat it to hell. If you did, then shame on you for not telling us.
You could've broken the pivot which would allow the engagement mechanism to move, but not actually engage the clutch. It's an inexpensive part, but the labor to replace it won't be. The only way you can tell for sure would be to drop the tranny.
Old Apr 29, 2005 | 01:19 PM
300zx nw's Avatar
what is the pivot??
Old Apr 29, 2005 | 02:31 PM
Fast240Z's Avatar
I had a clutch that was slipping, and I went to pass someone and threw on some throttle, and then my clutch died. I ended up finding out that I actually ripped off all of the clutch face, and there was NO clutch left.
Old Apr 29, 2005 | 03:51 PM
bardabe's Avatar
Bad Speller
Originally Posted by Fast240Z
... and there was NO clutch left.
ha ha ha ha man Ima in a laughing spree today. lol I did that to my sister's civic. it was pretty funny, Hondas can't handle burn outs. it was not even good and the clutch died. I remember doing endless drifts on my Z and the clutch never went out. Z's clutches are untouchable for a stock HP range ha ha . dont U guy's agree? u can beat the **** out of a Z32 clutch and still get it to the house to replace it. unlike cheap old Hondas. POS ha ha ha ha Honda good Joke whahahaha Civic what a clown he he Si whahahahaha good stufff. my $.02
Old May 1, 2005 | 10:02 PM
91zxtt's Avatar
what is the pivot??
A pivot ball. It's what the clutch fork sits in.
Jennings.brent6
May 30, 2014 11:10 PM
MadZ420
24
Mar 7, 2009 10:05 AM
300zx nw
May 12, 2005 04:31 AM
300zx nw
Apr 21, 2005 12:20 AM
300zx nw
350Z Performance / Technical
Apr 20, 2005 11:23 AM
