pulleys
Old Nov 4, 2006 | 09:48 AM
drkfilldschemis's Avatar
pulleys
i can't seem to get my pulleys off
im using a ratchet but with every failed attempt its just making me more mad
is there sumthing simple im just missing or what, like im turning it the wrong way or what? cause i turn it both ways and the pulley still keeps moving and not loosing
please help
im mainly talking about the two that the ones that hold on the timing chain
Old Nov 4, 2006 | 10:30 AM
my86z's Avatar
I'm assuming you mean the cam pulleys?
You gotta use something to hold that pulley still while you're removing the bolt.
I use a broken timing belt with a Vice-Grip and a long bar, to hold the pulley. I've alse seen people use a screwdriver or metal bar to hold the pulley.
Old Nov 4, 2006 | 10:42 AM
alright i have to try that
so just stick the screw driver or sum device in there to jam it still so i can remove it just what your saying?
Old Nov 4, 2006 | 10:57 AM
my86z's Avatar
exactly. Use it going through one of the holes of the pulley. And wedge it to a surface of the head/block.
Old Nov 4, 2006 | 11:14 AM
okay i did that and my pulley isn't budging i cna't get teh nut loose
is it left loosely/right tightie
or is back wards than normal?
cuz its starting to **** me off
Old Nov 4, 2006 | 11:17 AM
my86z's Avatar
nope, you're right. Just turn the bolt "counter-clockwise" to get it loose. Chances are that they've never been removed. And are going to take a "big stick" to get them to loosen. I'd suggest using plenty of penetrating lube. Just spray it on. Let it sit for a while. And repeat muliple times. Hopefully that will help.
Or, if you're very carefull, try tapping on the bolt with a hammer. Sometimes, the corrosion just needs to be knocked around to release it's hold on the surfaces.
Old Nov 4, 2006 | 11:30 AM
thanks for your help man ur a lot of help
i forgot bout the lube
i'll try that now
Old Nov 4, 2006 | 12:09 PM
wreckedj30's Avatar
No Club Love
yo 86' who's your avatar..it looks like a skinny hitler/cartman...but i donno...sorry for jacking.too
Old Nov 4, 2006 | 12:22 PM
my86z's Avatar
There was a program, somewhere, that you could build your own "Southpark Characters". This was the closest I could come to that looked like me, back then.
Old Nov 4, 2006 | 12:26 PM
wreckedj30's Avatar
No Club Love
ahh, thats badd. you should build me one then...that'd be cool
Old Nov 4, 2006 | 12:28 PM
my86z's Avatar
I can't find the program or website anymore. I just had that saved on my PC for a while. I just decided it was about time I added an avitar to myself. And just resized it for use here.
Sorry man.
Maybe if you do a search, you might come across it in the web.
Old Nov 4, 2006 | 12:32 PM
wreckedj30's Avatar
No Club Love
alright then...if you ain't doning anything you should come to chat..
90PearlZ
Jan 14, 2008 09:51 PM
s13z31killer
Jan 6, 2006 08:26 AM
domsgarage
18
Feb 24, 2004 10:09 AM
cookiecutter
Sep 19, 2002 08:01 PM
skyman
Mar 24, 2002 08:32 PM
