pulleys
pulleys
i can't seem to get my pulleys off
im using a ratchet but with every failed attempt its just making me more mad
is there sumthing simple im just missing or what, like im turning it the wrong way or what? cause i turn it both ways and the pulley still keeps moving and not loosing
please help
im mainly talking about the two that the ones that hold on the timing chain
please help
I'm assuming you mean the cam pulleys?
You gotta use something to hold that pulley still while you're removing the bolt.
I use a broken timing belt with a Vice-Grip and a long bar, to hold the pulley. I've alse seen people use a screwdriver or metal bar to hold the pulley.
nope, you're right. Just turn the bolt "counter-clockwise" to get it loose. Chances are that they've never been removed. And are going to take a "big stick" to get them to loosen. I'd suggest using plenty of penetrating lube. Just spray it on. Let it sit for a while. And repeat muliple times. Hopefully that will help.
Or, if you're very carefull, try tapping on the bolt with a hammer. Sometimes, the corrosion just needs to be knocked around to release it's hold on the surfaces.
I can't find the program or website anymore. I just had that saved on my PC for a while. I just decided it was about time I added an avitar to myself. And just resized it for use here.
Sorry man.
Maybe if you do a search, you might come across it in the web.
Sorry man.
