PROBELMS WITH MY 300zx HELP!!
I recently bought a 300 and when i go out driving/drifting and then i cut it off after driving a little while after i decide to crank it back up..it doesnt i turn the key but nothing happens it doesnt even turn over..after i leave it there for a while it will crank back up why is this does anybody have a similar problem they had but figured out the problem
on the back of the starter motor theres a single black plug that connects to a spade. this is an inhibitor switch for the car, hook it back upto the back of the starter motor and crank it over. you'll find that 99.9% of the time thats the problem, z31 starter motors are generally tough items.
I have another question. My radiator fan does not cut on automatically when i crank it up causing it to get extemely hot. To solve this i spliced the wires and hooked the positive side to one of my fuses inside the car. Is there anyway around this?
We tried cleaning the clip on the starter but didn't get the car to try to turnover. Took the starter off and the starter is fine. Would the security system prohbit the car from starting, and if would how can we turn off the security system. Or is there aother check to see why it want start.
Well i have it narrowed down fire is getting to the relay but not to the starter from the ignition. I temporarily fixed it by putting a button onto the starter so now i must pop the hood to crank it but i soon hope to figure it out
I have a 1984 300Zx Turbo and I had the same problem, when I would turn the key all my instrument cluster lights would go off as if there was no juice. I figured out that it was the security alarm. All I had to do was take of the panel right where your knees are on the drivers side and you'll see a fuse hanging down connecting two wires, disconnect the fuse and this should disable the power cutoff.
well first of all that pics a little big, okay so the starters fine? righto, get a manual and learn about inhibitor switches. next on the list the thermo fan only works when air con is switched on to help aid in cooling the charge air.
Okay now the starter problem, check main fuse box for a blown fuse dont ask me which on im all out sorry, try tracing wires and kicking things, if nothing else, take it to someone and get them to hae a look, you said you can crank it over with the button? well start it and drive it to an auto electrician.
ok guys i fixed it!!! somehow! and it is not with the push button i know it's so great and you wonder how did i do it? Well all i did was put a radio in it since there wasnt one in there before. The security system was inhibiting it from cranking. The radio stores some securtiy info and putting a radio which i put a aftermarket jvc and it fired right up. I just wanted something to listen to in my car so i put that and i turned the key and holy **** it cranked without pushing the button under the hood
yeah thats what joe was telling me..but it is a good thing it works now cause i' just ordered my suspension and i am getting ready to order a body kit for it cause the front bumper is all screwed up but i am not getting some fancy one that wil lmake my 300zx turbo look unclassical
my personal favorite has always been the Xenon kit for the 84-85 models.
http://www.zcarparts.com/store/merch...egory_Code=8AP
i dont like how the xenon angles in on th fascia. the kaminari just looks so clean.
http://www.kaminari.com/products/84300ZXEarly.htm
nismo619
Jun 11, 2012 07:56 PM
