Oil restrictor
Old Jul 7, 2011 | 12:40 AM
86_VG30ET_Z31's Avatar
Oil restrictor
So i got a t3/t4 turbo from a friend an i checked it for shaft play on it seems ok checked the blades on both sides an they seem in good shape. An i want to install it but i heard that i would need an oil restrictor to not blow the oil seals on the turbo or is the oil pressure of the z31 good to not run restrictor on the turbo
Old Jul 7, 2011 | 05:10 PM
AZ-ZBum's Avatar
That's a new one on me. Who told you that?
Old Jul 7, 2011 | 07:01 PM
My friend had a restrictor on his honda car Setup cause his oil pressure was to high for The turbo an it would blow out the seals but i dont knoe if dats the zame for my z mine is a 86 turbo
Old Jul 7, 2011 | 10:19 PM
AZ-ZBum's Avatar
Bingo. Don't listen to Honda owners when it comes to stuff for your Z.
Old Jul 8, 2011 | 12:32 AM
Thanks alot i almost got all the next uPgrade put together just need nistune left
Old Sep 6, 2011 | 06:42 AM
oldjdmskool's Avatar
If it is a aftermarket T3 or t3/t4 make sure you oil line feed fit properly if so you won't need a restrictor cuz this part already got a restrictor build in it. usually a restrictor is use when a NA engine is converted to turbo since originally didn't came with one, or in case you upgrade the turbo, like say: instead of using a regular t3 or t3/t4, you use the t3/t04b or T04E or bigger size which the original Z31 oil feed line won't fit properly due to housing of the compressor will be in the way you will have to use a after market oil line and then use an aftermarket restrictor
Old Sep 6, 2011 | 08:00 AM
One gigantic ****ing sentence that also happens to be in bold.
And holy crap! the 90's passed dude, people are actually spelling out entire wrdzs nw dys......
/rant.......
beg3yrs
Aug 24, 2015 02:58 PM
nka04a
12
Apr 12, 2006 11:01 AM
stevo
350Z Performance / Technical
Oct 30, 2004 01:18 PM
stevo
Oct 26, 2004 07:10 PM
