oil cooler blues
Old May 9, 2013 | 05:37 AM
turbotim's Avatar
oil cooler blues
Can some one give me suggestions, I have a 85zxt and need to move the oil cooler I see the ones on ebay that attach to under the oil filter but what would I do, block off my stock lines, or get one of the 60 dollar cheapos that looks like it some what attaches to your stock oil cooler lines. I don't know if you have to cut your copper lines with hack saw with the cheapo ones or not! Man guess how much for the stock oil cooler from a Nissan dealer ship 800 bucks!!!!! crazy aint it
Old May 9, 2013 | 06:23 AM
eh? You would remove the stock oil cooler adapter & lines... you don't "cut" anything.
Click:
RedZ31 - Engine Oil Cooler
Motorsport! Z31 Oil Cooler Kit
Old May 9, 2013 | 04:19 PM
turbotim's Avatar
Ok I thought I heard a rumour that we cant block off our stock oil cooler lines because of the way the oil flows, so I didn't think I could use one with the oil filter adapter if its safe to block it off I would love to do it! And I thought it was hard to find the cooler cause our fittings are goofy sizes!
Old Jun 10, 2015 | 08:53 PM
ThoBackZ's Avatar
I have the same problem wit 87T. So what do you do with ol stuff???
Old Jun 11, 2015 | 08:34 AM
ThoBackZ,
Not sure if you read through those links... but I suggest doing so. You either need to adapt the stock lines (banjo connections and compression fittings) to work with the new cooler, or just buy an aftermarket sandwich plate and lines. What needs to be done depends on what you want and how you want to do it.
Old Jun 11, 2015 | 03:31 PM
ThoBackZ's Avatar
Thx for the info but I wondering what is done with the line coming out of the block where the old line come out? Because the new oil filter adapter has sending and return on it. So do you plug the in and out on the block?
Old Jun 12, 2015 | 09:51 AM
You remove it and use the one from the oil cooler kit. The sandwich plate mounts where the oil fiter would normally screw in:
Old Jun 13, 2015 | 08:28 PM
ThoBackZ's Avatar
So you take off the stock sandwich plate that bolts to the block and put on the one that come with the kit.
Old Jun 13, 2015 | 08:51 PM
Yus.
Old Jun 14, 2015 | 08:05 PM
ThoBackZ's Avatar
Thx for the help
Old Aug 4, 2015 | 09:28 PM
ThoBackZ's Avatar
Thx for all your help this kit worked very well
farqyj
Aug 17, 2015 04:30 PM
BDavis
Dec 8, 2011 01:56 PM
lts70
Dec 22, 2010 02:04 PM
theramz
Jul 27, 2004 08:38 AM
Splice
Sep 13, 2002 09:12 AM
