NT/turbo motors
Old Mar 9, 2007 | 12:34 AM
RedNoma's Avatar
NT/turbo motors
As I posted here a while back my dad and I purchased an '85 Z31 NT auto with a rough body. Well my dad may have came across another car we're going to look at tommorrow. It's supposedly an '86 turbo 5-speed car with a good body. The only problem is the motor is blown. I was just wondering what are the differences in the two motors? We're thinking about getting the turbo and putting the good NT motor in it with the turbo and everything else. I'm assuming the NT probably has a little higher compression ratio. Is it other wise the same? Will it bolt up fine in place of the other motor? Thanks.
Old Mar 9, 2007 | 12:40 AM
SpeciallySpiked's Avatar
I'm a Registered User!
all I'm going to say is that it will bolt up in the same spot... i'll let the other guys take care of the rest
Old Mar 9, 2007 | 12:56 AM
RedNoma's Avatar
Yeah, I just found that from searching. I couldn't find anything on the compression or any other differences. Thanks.
Old Mar 9, 2007 | 02:35 AM
TRGBassGuy's Avatar
Here is a link to some good information on the engine in the Z31.
http://z31.com/wiki/doku.php?id=info...basic_z31_info
Old Mar 9, 2007 | 06:57 AM
AZ-ZBum's Avatar
http://www.az-zbum.com/information.basic.shtml
http://www.redz31.com/pages/turbo.html
Old Mar 9, 2007 | 06:59 AM
smokey's Avatar
yea theres a lil bit more that you have to do besides just bolting on the turbo parts....have fun
Old Mar 9, 2007 | 02:23 PM
RedNoma's Avatar
Okay. I just got back. It's in a lot better shape than ours. It's turbo, but it's missing the turbo. He said that he had the motor checked out and the bottom end is fine. Supposedly the lifters are the problem. I'm guessing he was revving it high and the lifters floated. I'll check those sites out. Hopefully the top ends will switch over. The guy wants $400 for it. Good deal?
Old Mar 9, 2007 | 03:08 PM
AZ-ZBum's Avatar
If he floated the lifters, there's also a chance they hit the pistons. Which would be bad also.
Old Mar 10, 2007 | 10:52 AM
RedNoma's Avatar
So if I take off the heads and the cylinders/pistons are good will the top ends switch out?
Old Mar 10, 2007 | 08:49 PM
z-hag's Avatar
Queen of Yachts
if yer gonna take the thing apart--why dont you rebuild the turbo motor, buy for 300-400$ a turbo to replace the missing one and have fun..........mixing turbo and nonturbo stuff does not always get you where you wanna go......and if you rebuild the turbo motor, the result should last you another 250k miles, anyway----and the initial 600$ IF the body really is good-might be slightly high. but you will havea good car in the long run that will get you a fair return price at sale.....oh--and i removed the aftermarket airfilter from my 84 turbo and now get much better performance......stay stock--less pricey and more responsive.......
Old Mar 10, 2007 | 10:32 PM
RedNoma's Avatar
Yeah, I was just wondering if the topends are the same.
Old Mar 11, 2007 | 03:03 AM
AZ-ZBum's Avatar
yes. the heads are the same.
todd5854
Apr 2, 2014 09:21 PM
lts70
Nov 27, 2010 08:16 AM
CanyonCarver
May 21, 2005 07:06 PM
ralliarton18
Nov 20, 2003 05:37 PM
NissanObsessed
Mar 19, 2002 09:43 AM
