Hey Everybody,
I haven't been able to get my 300zx turbo to run ever since it quit out of know where. It no longer sparks and no longer pumps fuel. I have replaced the ignition module, coil pack, and crank angle sensor and still have seen no difference. I really don't know what else i can do. So, if you can help it will be greatly appreciated.
Thank you.
Thank you.
YEAR ?...... 300zx start/fuel issues
Thank you.
If you've done all of that the next thing to check is the ECU control.Originally Posted by FlyAssMelonBall
Hey Everybody,I haven't been able to get my 300zx turbo to run ever since it quit out of know where. It no longer sparks and no longer pumps fuel. I have replaced the ignition module, coil pack, and crank angle sensor and still have seen no difference. I really don't know what else i can do. So, if you can help it will be greatly appreciated.
Thank you.
How do i check that?
How much power should I be getting to my crank angle sensor?
I assume 12 volts is that right?
