Leak from underneath Tranny
Guest
Posts: n/a
I have a leak from underneath my 5-spd transmission. It feels like oil but I have consistantly checked the oil level daily and the level is fine. Where could this leak be coming from and how can I stop it? Is there some tranny stop leak out there that would work? Is there some place that I can check the level of the gear grease without having to get underneath the car?
Guest
Posts: n/a
Mine does the same thing I think it comes from the gear shifter gasket is it leaking on your cat? if so it probably is that gasket
Taste Test... 90 weight gear oil has a very distinct flavor, much more pleasing to the palet than common motor oil....
Go to "jiffy-lube"... if they don't total your car in the process, they should be able to determine your fluid levels for you.
studio110
Jun 9, 2012 08:24 PM
d33zdrama
14
Mar 3, 2012 05:15 PM
