intercooler questions
Old Nov 28, 2010 | 08:01 PM
tonsoffun300zx's Avatar
West Coast!
ok so im getting ready to purchase an intercooler but my question is, are any of you running a godspeed or cx racing fmic. im looking at godspeed's spec a:
http://www.godspeedproject.com/store..._image&pID=175
or cx racings:http://www.cxracing.com/mm5/merchant...gory_Code=INCO
the god speed i/c is 250 and the cx racing 169 but im not to sure if they are that great of companies. if not im just going to hit the j-yard and try to come up with a saab or volvo i/c and suggestions are greatly appreciated T.O.F
p.s. if there are any similar intercoolers that you guys know of that are good please let me know thanks
Old Nov 29, 2010 | 03:28 PM
As far of intercoolers, the only cheap ones that have been reported in the Z and DSM world that work good are treadstone and godspeed.
Old Dec 1, 2010 | 11:35 AM
West Coast!
hey has anyone heard of good results from using an intercooler with a heat dispersant coating? and where to get it applied at?
Old Dec 1, 2010 | 03:36 PM
never heard of anyone doing that. heat dispersant coating? ehhh, most coatings are meant as insulators. In all my life of seeing electrical heat sinks, intercoolers, radiators, and even webbings on air cooled engines, NONE have ever had a coating.
Old Dec 1, 2010 | 04:54 PM
West Coast!
i've been researching it and there are a few places the biggest one is crucial racing but idk. im just trying to weigh my options im getting ready to do a few upgrades thats all.
Old Dec 2, 2010 | 01:55 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
I wouldn't buy a CXracing IC, thats just me. If I had enough money I'd get either a Godspeed (they make good radiators from what I hear), or a Greddy IC.
Old Dec 3, 2010 | 11:49 PM
West Coast!
ok so same side fmic or standard fmic?
Old Dec 18, 2010 | 11:12 AM
ctom24's Avatar
treadstone makes a good spearco clone. and i think same side intercoolers will allow for shorter piping which obviously is better lol i also stumbled across this one if you want something larger.
http://www.treadstoneperformance.com...82+Intercooler
Old Dec 20, 2010 | 12:08 AM
West Coast!
thanks anyone else have suggestions?
Old Dec 21, 2010 | 07:17 PM
reddzx's Avatar
http://www.turboneticsinc.com/node/82
Old Dec 30, 2010 | 03:04 AM
West Coast!
cool thanks guys but im going to have to postpone the i/c set up my whole digital dash went out but thanks for the responses. ill update soon and also one more question what size i/c piping should i go with i have a spare 240sx tb laying around should i upgrade sence im dealing with the area?
Old Jan 6, 2011 | 07:11 PM
reddzx's Avatar
http://www.godspeedproject.com/store...roducts_id=175
Old Jan 10, 2011 | 01:38 AM
West Coast!
hey i was thinking about going with a volvo intercooler kinda like nismo, cause there are alot of them at the local j-yard any advise on which model it comes off of and approx. how many lbs if boost they can handle?
Old Feb 4, 2011 | 09:48 AM
RB20ZR's Avatar
I bought a Mishimoto Z series intercooler and am in the process of a vertical rad swap right now.
Old Feb 4, 2011 | 12:15 PM
West Coast!
you doing the vert. rad. for inter cooler fitment purposes?
Old Feb 14, 2011 | 09:16 PM
West Coast!
ok so i am picking up an sr20det smic for dirt cheap and going that direction im only going to go a little beyond stock cause im not sure how many lbs of boost the injectors will handle i was thinking 1 bar but i would be fine with 10 lbs
Old Feb 15, 2011 | 12:48 AM
1 bar is atmospheric pressure, 14.7psi I believe, pretty decent difference from 10lbs. and stock is really low on those cars to. So I think 10 is a healthy start.
Old Feb 15, 2011 | 12:54 AM
At blowing it up, these cars have a hard enough time with detonation at stock boost with stock timing on 91 **** gas.
Old Feb 15, 2011 | 10:04 PM
West Coast!
sorry for some reason i could have sworn 1 bar was 12 lbs my bad i want 10 lbs to the manifold. And yes hoov i run 91 with octane booster and have a 1.5 quart oil cooler installed, and im looking into the maxima 90 amp alt. so i can run the lincon electric fan i know about detonation. you had the car boosting at 8 lbs when i first purchased it isn't a big jump 10 lbs
Old Feb 16, 2011 | 12:22 AM
First off, octane booster does as much good as putting a magnet on your fuel line. And yes 10psi on a car that can barely handle 8 is a BIG difference, especially when you melt a hole in the pistons or lose a ring land. Both of which will most likely make the block unusable. Ontop of that you are only running 270cc injectors and have no way of monitoring AFR's, or any way to tune it.
Old Feb 16, 2011 | 09:36 AM
West Coast!
then i'll just have to get a wideband won't i?
Blue280zxTurbo
Apr 23, 2009 11:27 PM
79bigbore280zx
Aug 20, 2003 11:16 AM
Exessive26
Jul 1, 2003 09:45 AM
mr mike
Jun 6, 2003 03:05 PM
donovon
Apr 9, 2002 04:53 PM
