intercooler questions
ok so im getting ready to purchase an intercooler but my question is, are any of you running a godspeed or cx racing fmic. im looking at godspeed's spec a:
http://www.godspeedproject.com/store..._image&pID=175 or cx racings:http://www.cxracing.com/mm5/merchant...gory_Code=INCO the god speed i/c is 250 and the cx racing 169 but im not to sure if they are that great of companies. if not im just going to hit the j-yard and try to come up with a saab or volvo i/c and suggestions are greatly appreciated T.O.F p.s. if there are any similar intercoolers that you guys know of that are good please let me know thanks |
As far of intercoolers, the only cheap ones that have been reported in the Z and DSM world that work good are treadstone and godspeed.
hey has anyone heard of good results from using an intercooler with a heat dispersant coating? and where to get it applied at?
never heard of anyone doing that. heat dispersant coating? ehhh, most coatings are meant as insulators. In all my life of seeing electrical heat sinks, intercoolers, radiators, and even webbings on air cooled engines, NONE have ever had a coating.
i've been researching it and there are a few places the biggest one is crucial racing but idk. im just trying to weigh my options im getting ready to do a few upgrades thats all.
I wouldn't buy a CXracing IC, thats just me. If I had enough money I'd get either a Godspeed (they make good radiators from what I hear), or a Greddy IC.
ok so same side fmic or standard fmic?
treadstone makes a good spearco clone. and i think same side intercoolers will allow for shorter piping which obviously is better lol i also stumbled across this one if you want something larger.
http://www.treadstoneperformance.com...82+Intercooler |
thanks anyone else have suggestions?
cool thanks guys but im going to have to postpone the i/c set up my whole digital dash went out but thanks for the responses. ill update soon and also one more question what size i/c piping should i go with i have a spare 240sx tb laying around should i upgrade sence im dealing with the area?
hey i was thinking about going with a volvo intercooler kinda like nismo, cause there are alot of them at the local j-yard any advise on which model it comes off of and approx. how many lbs if boost they can handle?
I bought a Mishimoto Z series intercooler and am in the process of a vertical rad swap right now.
you doing the vert. rad. for inter cooler fitment purposes?
ok so i am picking up an sr20det smic for dirt cheap and going that direction im only going to go a little beyond stock cause im not sure how many lbs of boost the injectors will handle i was thinking 1 bar but i would be fine with 10 lbs
1 bar is atmospheric pressure, 14.7psi I believe, pretty decent difference from 10lbs. and stock is really low on those cars to. So I think 10 is a healthy start.
(Post 291098)
sorry for some reason i could have sworn 1 bar was 12 lbs my bad i want 10 lbs to the manifold. And yes hoov i run 91 with octane booster and have a 1.5 quart oil cooler installed, and im looking into the maxima 90 amp alt. so i can run the lincon electric fan i know about detonation. you had the car boosting at 8 lbs when i first purchased it isn't a big jump 10 lbs
(Post 291156)
then i'll just have to get a wideband won't i?
