HELP! I cant get my crankshaft pulley bolt off
Old Jun 2, 2006 | 01:24 PM
Turbo86's Avatar
I cant get my crankshaft pulley bolt off, in the middle of timing belt change ... I've tried everything, even soaking it in wd-40 and a 240 ft lb 1/2" impact wrench didn't budge it, 25" breaker bar just moves the pulleys ... tried to secure the pulleys with strap wrenches, assec. belts (no-go) ... that trick with the breaker bar and starter motor to crack it I have not tried, I'm scared to, but I may try it ... what about a bolt cracker or cutting off the pulley and buy new one ... I'm getting to that point because the cars just a giant paper weight at the moment ... I need some crazy ideas people and some real help, I need all you Z gurus to respond. It's an 86 turbo if it matters
Old Jun 2, 2006 | 01:34 PM
WD40 is as good as water.... Get some PB Blaster for your supplies.
Old Jun 2, 2006 | 01:55 PM
Turbo86's Avatar
actually it was prolong pent. lubricant but I've seen the pb blaster at the store, does it make that much of a difference?, what's in it acid? ... I'll try it ... anything else?
Old Jun 2, 2006 | 02:06 PM
Well, if you have a breaker bar, just slide a pipe on the end.... the longer the better (for more leverage). Just don't use a ratchet as it will prolly break. If you are doing this from the top side, maybe try jacking up the front & getting at it from the bottom. Make sure the car is in gear (5th is best), e-brake on, and tires are chalked.
Old Jun 2, 2006 | 02:20 PM
jfairladyz's Avatar
I've yet to encounter a crank pulley bolt that couldn't be broken loose by the torque of the starter motor. Just make sure the breaker bar is wedged in the direction of engine rotation I've also yet to ever have a bad incident occur while breaking the bolt loose in this way. On the same note however, take caution if you go this route not to hurt yourself. I'd try Nismos method first with putting the car in gear and ensuring it can toll.
Old Jun 2, 2006 | 10:56 PM
Turbo86's Avatar
got it off! can't believe it ... I made a home made tool ... long flat steel bar, got a 6mm x 50mm bolt, drilled a hole thru bar, put bolt thru hole and into one of the six smaller holes,wedged bar against ground, and used a breaker bar on big nut (I also bought and used some pb blaster too), worked like a charm and I didn't have to do the scary starter method ... ok now how many rotations do I have to do before all 3 timing punch marks line up with the 3 other marks ... I get real close but not there yet ... they have to be dead on correct?
Old Jun 2, 2006 | 11:59 PM
jfairladyz's Avatar
If you haven't removed the sparkplugs do so. It will make aligning those marks much easier as the engine wont see any compression resistance.
Old Jun 3, 2006 | 09:11 AM
Turbo86's Avatar
how many times do i have to go around before they line up we went more than 24 complete times lining up the marks and one time was super close but one was a hair off to the other 2 was that it ... it has to be dead dead on right
Old Jun 3, 2006 | 09:27 AM
jfairladyz's Avatar
Try this: http://www.z31.com/repairs/tbelt.shtml
Old Jun 3, 2006 | 11:03 AM
Turbo86's Avatar
ok the write up says get all 3 marks close ... I thought it was supposed to be dead on. is there wiggle room where it just has to be close ... I have it close right now, the right cam is on the crank is on but the left cam is slightly before the mark 1/8 inch or so ... should I fudge it so all 3 marks are close as possible instead of 2 dead on
Trex
Nov 10, 2011 04:29 PM
Etherealwolf
Jun 27, 2011 02:56 AM
vrocious
Jan 18, 2011 09:34 PM
Cali79zx
Aug 25, 2010 11:01 PM
gostlrs
Nov 29, 2008 12:05 AM
