Half-shaft replacement!!!!
Old Feb 14, 2007 | 04:31 PM
my86z's Avatar
Angry Half-shaft replacement!!!!
Who here has actually replaced thier 300zx's CV half-shaft?
I needed to replace my passenger side unit this week. So, I ordered the part. Had to wait a few days for it to get here, since it was not a normally stocked item. I rent a lift in a garage, yank out the parts to allow me to remove the axle. And finnaly remove the part, after 30 minutes of cussing at the shock mount bracket under the swingarm. Upon installing the new axle, I'm noticing that it won't "click" into the retainer within the rear end. I didn't think anything of it, until I go to bolt up the outer end to the wheel shaft. It's about 2" away from the mating flange. So, knowing that it's a CV joint, I know it's got a little bit of adjustment. I pull on the shaft and it won't reach without pulling out of the rear end. I played phone tag with the supplier's tech support. And I measured just about every aspect of the bad and new axles. Noting their differences. And by the end of the day, it boils down to....... The right side is for the left, and the left side is for the right.
Has anyone come into this problem in the past? Or are my axles that much FUBARed?
Old Feb 14, 2007 | 05:48 PM
RodMoyes's Avatar
Doesn't post much...
You probably just got a mis-boxed part. It happens ALL THE TIME and it totally sucks. Try again
Rod.
Old Feb 14, 2007 | 06:08 PM
my86z's Avatar
Not really. The tech support guy and I went over the dimensions of both part numbers. And the one I need, is for the opposite side. Which didn't make much sense to me. It's just working out that way. it's almost as if my differential is on the opposite "offset" as it should be.
silverzxbullet
Nov 19, 2018 06:56 PM
garretthes
May 1, 2012 09:36 PM
LemonHead
Apr 2, 2012 08:01 PM
Lesnocker
Sep 26, 2009 05:20 AM
Z_guy
Mar 13, 2009 06:42 PM
