Engine Doesn't Like the Air Filter Box
Old Aug 31, 2014 | 09:11 PM
surfrocker1's Avatar
At my wits end.
1986 2+2 N/A
With the engine running, when I bolt down the lid for the air filter box, with or without an air filter in place, the engine begins starving for air and eventually stalls. If I lift the lid before it stalls it returns to a normal idle.
I've checked the passages and there are no blockages.
The only code I'm getting is 11 Crank Angle Sensor. I will address that, but don't see a connection to the above issue. Correct me if I'm wrong.
Thanks for your help.
Old Sep 1, 2014 | 02:59 PM
rogerz's Avatar
Grumpy & Helpful
does it run normally if you put it in gear and drive off? put a vacuum gage on it and see what happens when you do the air filter lid. you may think it is starving for air and something else is happening.
need2fix
Sep 13, 2010 06:39 PM
Mtnangie
16
Aug 6, 2007 10:03 PM
jrindo
Aug 22, 2005 11:17 AM
Heat Rave R
May 31, 2005 02:21 PM
stev240z
Aug 30, 2002 01:43 AM
