dash lights won't turn on
Old May 30, 2006 | 10:01 AM
jdatcher's Avatar
not one light on the dash or back lights work when i turn the key. the car will start but no dash lights help.
Old May 30, 2006 | 06:40 PM
jfairladyz's Avatar
first check the fuses. The dash lights, parking lights, and taillights operate on the same circuit. If the fuses check out then it is most likely the switch which is an easy and free fix.
Old May 30, 2006 | 10:03 PM
drlew's Avatar
I sometimes wonder if my dash lights are working, but they are just really, REALLY dim. I wish I knew how to get them brighter.
Old May 31, 2006 | 12:00 AM
jfairladyz's Avatar
should be a rheostat to control the brightness of the dash lights. Not sure where it is on the Z31's though But I can't recall a modern era car that didn't have a dimmer.
Should look something like this though i assume: http://cgi.ebay.com/ebaymotors/1988-...QQcmdZViewItem
Old Jun 5, 2006 | 07:31 AM
jdatcher's Avatar
does the switch controlle the gauges, ac/heat thay also aren't working.
Old Jun 5, 2006 | 10:09 AM
jfairladyz's Avatar
yes the rheostat controls the illumintation for all the dash lights including the gauges and the ac/heat lighting. If you mean you ac/heater just isn't blowing then thats soemthing else. But if you're referring to the lighting on the control unit, then yes, the switch controls that too.
Old Jun 5, 2006 | 10:37 AM
jdatcher's Avatar
i'm not getting a reading on the gauges, no acc. are working. only thing in the car that is working is the windows go up and down and the mirrors move nothing else maybe a bad ground i checked the relay and is good please help me driving me CRAZY
kr11zzz31
Sep 8, 2011 07:39 PM
nis88300zx
May 28, 2005 11:20 AM
mattduskater
14
Feb 3, 2005 08:09 PM
trivan
Jul 8, 2003 05:40 PM
Sama3d
Oct 4, 2002 08:57 PM
