87 300zx turbo, a/t running issues
Old Feb 27, 2020 | 03:40 PM
SK8ERSQUREL's Avatar
So anyone's that's followed my posts may know I just got it running after 5 years of sitting, but I just drove it for the first time. It kept cutting off, like the fuel pump would shut off or something similar to that, and its overheating. I'm thinking my thermostat is clogged (I noticed some debris in the water suction hose), but as far as it cutting out I'm not too sure. Any ideas?
Old Mar 28, 2020 | 03:26 PM
Please help, cant go past 10 mph
:wtf2: Ugh I'm losing my mind here! So after redoing injectors, I had gotten it running. It would cut out at the end of first if I'm stepping on it or early into second if cruising, doesn't stall just no response. I went to take it apart again, my intake manifold bolts were loose. So I just redid cooling system, valve covers and lower and upper intake manifold, used shellac on everything and a torque wrench, just went for a drive same exact issue. I do notice air sounding like it's leaking/hissing near the throttle body on driver side of the intake, by the injectors. Spraying starting fluid near there had absolutely no effect on it. In park it will rev all day long no problems. Only in gear will it cut off I'm moving any faster than a jog. Can anyone help me I'm lost as to what it could be now.
lord of the z
Jul 2, 2017 07:00 PM
Donn144
Dec 17, 2015 10:17 PM
Ken_300zx
Jan 27, 2015 07:28 PM
joshers21
Mar 27, 2012 11:05 AM
bigbronc
Mar 8, 2005 11:59 AM
