86 300zx T Burning out??
Old Sep 7, 2001 | 08:49 AM
silvrhand's Avatar
Snazzy Title
Re: 86 300zx T Burning out??
First off have you given it the much needed tuneup?
- plugs
- air filter/new intake
- oil/oil filter
- plug wires (check to see if they need replaced)
- cat converter (make sure it's not plugged)
- fuel filter
and so on.. Also how many miles does it have? You may want to take it and have a leakdown test done on the cylinders to see what kind of shape it's in. Also I'm sure you could install a boost gauge to make sure you are reaching peak boost on the turbo.
- john
Old Sep 7, 2001 | 04:17 PM
silvrhand's Avatar
Snazzy Title
boost gauges are around 100$ us, you should be able to install it yourself not that big of a deal..
You can also do a intake for 100$, and from what I understand since you have a single exhaust there are a lot more performance options for the Z31 and cheaper than my car (Z32 TT).
I'm sure someone else will have good suggestions on how to turn up the boost, avoid detonation, and other things in general on the Z31..
- john
Old Feb 17, 2005 | 05:15 PM
chronic420510's Avatar
I have a 86 300zx and I can burn out like there is no tomorrow. O How much horse power do i have it is a non-turbo?
Old Feb 18, 2005 | 03:44 PM
bigbronc's Avatar
i also got an 86 non turbo and it can smoke the **** out of the tires. but its a 5-speed. does it feel like its laking power or just wont spin em'? if its laking power the run your self diagnosis. mine lost all its power once and ended up being something to do with its computer. the computer and electronics are ****ed up on these little cars. confusing as hell to me. also ive never had a problem w/ automatics neutral droping them but it is reall bad on em .
Old Feb 20, 2005 | 11:35 AM
looking...
I am looking for a short shifter for my 86 300zx 5 speed, can anybody help me find it?I have looked all over and can not find it for a 86? please email me if you guys know where i can find one thanks... Rich
Old Feb 21, 2005 | 01:11 AM
entropy31's Avatar
The Cake Is A Lie!
here you go
Old Mar 2, 2005 | 12:18 AM
Nihilanthic's Avatar
Find a parking lot, turn the wheel as far as you can (but dont hold it past where the tires go and burn out your PS pump :P) and just give it gas, it should burn out, especially if its a open rear. Bleach works great for making tires slippy!
If its an auto and you dont want to neutral drop, just power brake. STOMP the brake, STOMP the gas, then let off the brake. FYI, *built* automatics can be neutral dropped. There is also some race transmissions with either a stall torque converter that lets the engine slip up to a certain rpm and wind up the torque converter like a spring (and let big turbos spool up before launch) and/or transbrakes that engage 1st and R at the same time so you can rev up against the torque converter at a staging light, and then release R *VERY* quickly and take off. It even has the Reverse lights on while it does it! Very fun thing. I've seen many a car pull a full wheelie with one of these, giant slicks and enough raw power.
With a manual, rev, drop clutch, and floor it. Just dont do it on expensive tires!
Old Mar 7, 2005 | 11:03 AM
wilson101's Avatar
This Thread Is 4 Years Old.
Old Mar 7, 2005 | 11:08 AM
00Evan's Avatar
Banned
wow, all i have to say is wow..
and you wonder why you guys are so easy to pick on LOL
Old Mar 7, 2005 | 02:47 PM
Redbeauty84ZX's Avatar
haha WoW thats good stuff.
NismoPick
Sep 21, 2009 09:00 AM
81-280zxnt
Sep 9, 2009 07:10 AM
91Zman
15
Jan 21, 2006 02:57 AM
2000SR20
Oct 16, 2002 05:28 PM
zerodown765
Aug 30, 2002 12:20 AM
