86 300 NA, Is my fuel pump going bad ?
Old Dec 22, 2017 | 10:21 AM
Mojobaby27's Avatar
Went to start my 300 last night and didn't hear the normal priming hum of the fuel pump, the car wouldn't start after five or six tries, so I unplugged and re-plugged the fuel pump under the back carpet and also took off the negative battery terminal in reconnected it, then I turn the key and I get the normal hum and it started right up? Does that mean feel pump is going bad or is it something else?
Old Dec 26, 2017 | 10:36 AM
Cobalt60's Avatar
Sounds more like a bad connection than a pump performance issue.
You could check the discharge pressure of the pump by installing a gage.
Old Dec 27, 2017 | 10:11 AM
Mojobaby27's Avatar
I'll check the electrical, thanks for the idea
I'll check the electrical power and relays, as well as the fuel pressure, I'm pretty sure I can get the gauges at the auto store, loan program or rental? Thanks
will update.
Old May 13, 2019 | 11:54 AM
Raylene's Avatar
Similar
Had a similar issue n pulled the panel trim behind pass seat and tested fuel pump relay. Put power on it n figured out that was the issue n not the 1000 other things it could be lol
Old May 13, 2019 | 03:30 PM
Tristan King's Avatar
fuel pump relay?
Okay; can you describe to me exactly where you found the fuel pump relay? I’ve been looking forever and can’t find it anywhere. Not under the hood, not by the fuse bix, I’ve heard behind passenger seat like you but not sure where back there. Just give me an in depth description
Old Jul 15, 2019 | 05:53 PM
TKZ3186T's Avatar
Here you go...
The fuel pump relay is on passenger side behind the door
You'll need to take the trim off to access the relay
n5554t
Sep 28, 2021 09:44 AM
SK8ERSQUREL
Feb 20, 2020 07:20 PM
kdxzx
Oct 3, 2013 09:35 AM
kdxzx
Oct 24, 2010 02:54 PM
JhnRX7
Apr 27, 2009 10:47 AM
