300zxt turbo upgrade
Old Sep 30, 2006 | 01:37 PM
my86z's Avatar
Since I've purchased my 1986 300zxt, I've noticed that I'm loosing boost above 6000 rpms. Actually it seems to start loosing power above 5500 rpms. Since I have some supporting modifications, and planning on one more in the near future, I would like to upgrade my turbo.
I'd like to hear what everyone, that has already upgraded to a larger turbo, thinks about thier setups. Especially on the boost indexing and drivability of the setup.
Thanks in advance,
Wink
Old Sep 30, 2006 | 01:44 PM
are you sure your actually loosing boost?? also if you truly are loosing boost...you should probably try to find out where its going??? are you running stock psi? just curious..
Old Sep 30, 2006 | 01:54 PM
my86z's Avatar
Well, considering I'm running a JWT ecu, and able to run 7000rpms, I know I'm running past the T3's flow capabilities. It pulls like a rocket until about 5500rpms. Then it falls on it face past 6000rpms. It's set at 11-13 psi of boost.
Old Sep 30, 2006 | 02:00 PM
it holds that though right? its not ACTUALLY loosing boost? its just runing out of top end on that tiny barbie hairdryer of a turbo...
Old Sep 30, 2006 | 02:08 PM
my86z's Avatar
From 2500 rpms to about 6000rpms, it holds like a rock at 13psi.
1985nissan300zx
FS: 300ZX (84-89)
Mar 7, 2012 10:29 AM
1985nissan300zx
Feb 29, 2012 07:40 AM
Sam
Jun 1, 2010 05:35 AM
chris patrick
Jan 11, 2004 07:11 PM
matthewj
Apr 25, 2003 07:55 PM
