1989 zx Power Steering Pump Removal
Old Nov 17, 2012 | 07:33 PM
mpv06c's Avatar
Today I began the process of removing the power steering pump. I have a few questions about the removal process for a 1989 300zx.
From what I have read, there are two bolts that attach the engine lift brackets to the block. The bolt that is higher up from the ground is easy to remove. So, first question is, what is the trick to getting the lower bolt out of the bracket?
My next question is this: Are there only two bolts to be removed from the mounting bracket (not the engine lift bracket) that releases the pump from the engine block? The manual that I have has some pretty crappy pictures in even crappier resolution that makes it nearly impossible to distinguish grease smudges from bolt heads.
Anyone have a nice series of pictures that shows the bolts the NEED to be removed in order to remove the power steering pump?
Thanks in advance
HexaggramJDM
Aug 17, 2011 09:07 AM
emo236
Feb 7, 2007 09:08 PM
z32gizzle
Jul 21, 2006 08:20 AM
90NA300ZX
May 9, 2006 03:16 PM
n_2_fairladyz
Nov 19, 2005 03:35 AM
