1986 n/a 5spd, used to hesitate above 4k, now rough all around
Old May 9, 2015 | 12:13 AM
Dr_Nic_T61's Avatar
I've searched, and the first few pages don't have any matching problems, so here it goes:
I've owned it for a few months now, ran perfectly. Put about 4/5K miles on it. About a few days ago, I noticed when I am in the 4000-4200 RPM range, it really struggles, more or less than that and it's just fine.
Today, it's gotten much worse. I almost couldn't make it home.
Seems like a fuel delivery issue? What's some really easy stuff I can check/replace?
Old May 9, 2015 | 09:28 AM
rogerz's Avatar
Grumpy & Helpful
doubt it is a fuel delivery issue in that it runs well below and above that range. A faulty fpr would fail above a certain rpm and then just continue to degrade. I'd look at something electrical. New dizzy cap and rotor might be all you need. my 85T had a miss when floored that disappeared once I did that. after that CHTS or O2 sensor might be a guess. Come to our (Z car club of Washington) next meet at the Red Hook Brewery in Woodinville May 12 Starts at 7pm but usually people come earlier. Meet the guys and pick some brains. ZCCW.org website. You don't need to be a member to meet up with us. We also have a drive to North Cascades on May 30.
Old May 9, 2015 | 12:47 PM
Dr_Nic_T61's Avatar
It USED to operate fine outside of that range, but now it's all over ;_;
Seems like something is degrading. I went to the store, and when I got back in the car, it all of a sudden started hesitating and choking across the band
Also, thank you for the invite. I'll have to come by!
Old May 9, 2015 | 01:52 PM
rogerz's Avatar
Grumpy & Helpful
jury rig a fuel pressure gage that you can see while driving.
Amazon.com: Actron CP7838 Professional Fuel Pressure Tester: Automotive Amazon.com: Actron CP7838 Professional Fuel Pressure Tester: Automotive
this would work or you could go to OReily and buy an oil pressure gage and some fittings. that 1/8 inch plastic tube that often comes with it is stiff enough to thread under the hood and then close the hood and have the gage where you can see it while driving. might be your fuel pressure regulator is heading south. Fuel filter? need to put a gage on there and either confirm or eliminate fuel system as the problem.
if you were north of seattle we could meet up and do some testing but going to federal way is like the ends of the earth due to I-5 traffic.
Old May 9, 2015 | 03:33 PM
Dr_Nic_T61's Avatar
I work in Redmond and live in Federal Way, the drive wouldn't bother me if you wanted to meet up sometime. Do you have any of this stuff already on hand?
Old May 9, 2015 | 10:09 PM
rogerz's Avatar
Grumpy & Helpful
yes i have a lot been thru 3 z31 and 4 s130. if your car will make woodinville come to the meeting. i'll bring some stuff. email is krs@whidbey.com. probably easier than trading thru the forum pages.
Old May 14, 2015 | 09:53 PM
Dr_Nic_T61's Avatar
Replaced the fuel pressure regulator, and now it wont idle. She starts up, then almost immediately dies. Next few tries she immediately dies. Give it a few minutes and it repeats this behavior
Old May 15, 2015 | 02:15 PM
zxguy1986's Avatar
I would check the 2 solenoids on your air regulator, one for idle-up, the other for fast idle control. Before they die they can act intermittently - just to make you crazy. Easy test with your tester. Take them out, power them on and off in your hand. You can feel the click inside if they are working right.
Old May 15, 2015 | 09:26 PM
Dr_Nic_T61's Avatar
There's only two, right? I tested them and they both click!
I've now replaced all hoses near the FPR and its still a no-go
What could changing the FPR possibly have broken that I already haven't replaced???
Old May 15, 2015 | 09:54 PM
Dr_Nic_T61's Avatar
Unplugged the MAF and it runs just fine???? Is it time for a new maf?!?
Old May 16, 2015 | 07:23 AM
zxguy1986's Avatar
MAF a good place to check for dust, dirt and grime. Guys have blown it clean, carefully using cleaner - or just compressed air - but you're not supposed to touch anything in there while you clean it. You can check the archives here for MAF. I have replaced only one in my time, not a cheap deal if I remember..$400+? But ya gotta do what ya gotta do.
Old May 16, 2015 | 05:13 PM
Dr_Nic_T61's Avatar
I think if I try to clean it, it'll cause it more harm than good.
I'm starting to think more that it's not the maf. When it manages to start and stay started for a few seconds, giving it any gas will also kill it. It HAS to be something vacuum related, but I can't freaking figure out what. I've replaced so many vacuum lines and its still no go
Old May 16, 2015 | 05:21 PM
zxguy1986's Avatar
Check your vacuum line replacement work against Thumper's page. Lots of good pointers there. You may have missed or skipped something. Inside diameter of your lines is important because the vacuum system is not all that strong - and the diameter of the line can affect the vacuum power getting to those points where it is needed. And without a good OEM vacuum system, your engine is a loser. It's just the way Nissan designed it. Early 80s. Best they could do.
Vacuum Lines
At 29 years and counting, that Z should have had every OEM rubber vacuum line replaced by now. An orig OEM rubber line still working right would deserve an award!
Old May 16, 2015 | 09:36 PM
Dr_Nic_T61's Avatar
Vacuum Lines
Ok, so going over, I noticed a few more lines I also haven't replaced. Compared them to what I have been swapping in, they are exact. Swapped them out and STILL not running? I'm about to
qwiktune
FS: 300ZX (90-96)
Jul 7, 2014 08:34 AM
1986Z-REX
Apr 5, 2014 09:29 AM
Flacster
Apr 28, 2011 09:20 AM
z-hag
FS: 300ZX (84-89)
Dec 25, 2006 10:24 AM
racerbasi
FS: 300ZX (84-89)
Oct 29, 2006 07:41 AM
