Will a VG30DETT turbo kit work with my car?
Old Sep 28, 2013 | 04:20 PM
Hakkapell's Avatar
http://www.ebay.com/itm/TWO-GT28-Turbo-Kits-for-90-96-Nissan-300ZX-VG30DETT-Z32-Coupe-Turbocharged-ONLY-/230970504020?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c6ea3354&vxp=mtr
I need to know if that would fit in my 86 NA Z31. I'm working with a brother-in-law, and he insists that it'll fit, but I have my doubts. Thanks to whoever can help.
Old Sep 28, 2013 | 04:22 PM
rogerz's Avatar
Grumpy & Helpful
if you have a torch and a welding outfit and are good at using them.
Old Sep 29, 2013 | 04:02 PM
ken99's Avatar
There's doesn't appear to be anything in the kit that modifies fuel management. With the higher compression of the NA engine, you run the risk of running the engine too lean which could burn it up. If you proceed and get it all to fit and work, I'd setup the turbos to run minimal boost. To really make the investment work right, you are going to need a different ECU, injectors and an upgrade to the fuel pump. IMO, a twin turbo setup is a waste of money on a single cam VG. A single turbo kit will work just as well, a better chance of fitting in the engine bay and cost less money.
Old Oct 6, 2013 | 01:35 PM
FlyingT's Avatar
With enough cutting, welding and money, it could be made to fit, it has been done before. But as Ken said, it would be much easier, cheaper, and only work as well as a single larger turbo, which would fit in much better.
Old Oct 14, 2013 | 09:17 PM
AZ-ZBum's Avatar
It has nothing to do with the compression ratio. It has to do with the fuel injector size. They just don't flow enough fuel.
And no. That kit will not bolt onto a Z31's motor.
Evan Faris
15
Jun 28, 2013 04:19 PM
plyrathrt
FS: 300ZX (90-96)
Apr 14, 2011 11:34 AM
Stronginchrist
33
Apr 21, 2010 06:51 PM
280ZX_AV8R
Oct 31, 2005 09:22 AM
emo236
Dec 19, 2004 10:18 PM
