this is whats up
Old May 11, 2002 | 06:17 AM
Spot's Avatar
Re: this is whats up
it could be the throwout bearing, they tend to start making a noise when they're on their way out. if you do need a new clutch, that would be a good time to replace the throwout bearing, and the input seal on your tranny, and the rear main on your engine. you shouldnt be losing tranny oil unless you have a leak. if you don't know when the tranny oil was last changed then it's probably time to go ahead and change it.
I'm assuming you have a 5-spd if your friend says it could be the throwout bearing. automatics don't have a throwout bearing.
if you take the car to a shop for a new clutch and stuff, their first step will most likely be to tell you to bend over...
you're looking at about 300$ (at LEAST) for parts and labor.
it is a pretty big job though that is difficult to do yourself if you're in a hurry or lack the room and tools/equipment to do the work.
81 Black L28E
Dec 22, 2005 07:12 PM
pearly whites
Jul 18, 2004 03:05 AM
njordal02
Dec 17, 2003 02:59 PM
pearly whites
Oct 8, 2003 01:16 PM
CrAzY_84na
Sep 23, 2003 07:00 PM
