Engine Swap?
Old May 11, 2002 | 06:23 AM
Spot's Avatar
Re: Engine Swap?
first thing to check is your radiator cap. if it doesnt seal properly it WILL cause overheating. if that's not it, then have your radiator recored.
150k is nothing on these cars. all of mine have nearly that many or more miles on them and they're pretty healthy. one of mine has 243k miles on it, and is starting to burn oil though. I'm planning on replacing the rings and valve guides/seals and keeping her on the road.
it's hard to find a low mileage used engine, and a brand new one will run about 1200 bucks or so. that's just for the block and heads too. add to that all the gaskets you will need for the bolt on items, and fresh vacuum lines you will have to install and the number will really start to grow quickly.
Deafwolfy
Apr 30, 2015 05:19 PM
blacksheep
20
Mar 27, 2007 01:18 AM
uk175
Feb 5, 2004 05:42 PM
smokingzcar
Dec 5, 2002 07:57 AM
dstyle
May 13, 2002 06:14 PM
