Vibration
Old Nov 5, 2001 | 09:30 PM
Ghostz's Avatar
Well, maybe one more
From: Far away, locked up from anything interesting, almost in the dead center of the US
Vibration
Hey all,
I have been looking at an 87T 5spd. to replace my lost ZX. The only question I have is that when the car is rapped up to about 4000 rpm, the shifter vibrates ALOT. Any input as to what this is? I was thinking input shaft, or bearing, is there something else it could be? Thanx!
Ghostz
Old Nov 6, 2001 | 03:32 AM
Spot's Avatar
Re: Vibration
The driveshaft is balanced at the factory. You might also check the transmission mount and the bolts which hold it on. It's a big rubber mount and I've seen them separate before, so that's another thought. It's also a possibility that it's the engine mounts, they are rubber also, with a "gel" inside, perhaps one or both have cracked and the gel dried up/leaked out, and any vibration of the engine is being carried to the transmission.
Old Nov 6, 2001 | 09:32 PM
Ghostz's Avatar
Re: Vibration
Hmmm, how hard is it to change motor mounts? I've pulled the tranny on my old z, so that I know is not to big of a deal, but I never had the motor out...
Old Nov 7, 2001 | 04:04 AM
Spot's Avatar
Re: Vibration
you should be able to jack it up from the oil pan, using a floor jack and a board between the jack and the pan (so you don't smush it). you might try and have a length of 2x4 or somethin similar handy so that you can pry/lean the engine to one side or the other to make things easier. each mount has a stud coming out of the top and bottom with a 14mm nut on each stud. If you have a hoist, you can lift the engine like that instead of using a jack.
Old Nov 8, 2001 | 09:08 PM
Spot's Avatar
Re: Vibration
i got mine at nissan a few years back, although i've heard there are aftermarket ones available from places like carparts.com and others. you might try emailing strictlyz.com too!
Old Nov 26, 2001 | 06:32 PM
Spot's Avatar
Re: Vibration
ok, new one on me. what would cause them to go out of balance? (i'm not being a smartass, i am hoping i can learn something from ya)
Old Dec 1, 2001 | 11:42 PM
ZmeFly's Avatar
professional Z car owner
Re: Vibration
spot laid it down perfectly, thats what i would check and do because actcually it wouldnt hurt to replace theses things since they probably havent been since the car was new. and thats not so good on a car thats 13 years old.
watch out here comes my Z V8 powered and ready to roar
datdude407
Jan 20, 2011 09:59 AM
rtmorgan
Feb 25, 2009 03:15 PM
domsgarage
Jan 4, 2004 02:45 PM
BigE
Apr 20, 2003 02:39 AM
abox5
Nov 20, 2002 10:31 AM
