Vaccum leak?
Old Sep 1, 2002 | 01:51 PM
Spot's Avatar
Re: Vaccum leak?
If you've never replaced the vac lines in your z, then it sounds like a good time to do it now considering they're all nearly 15 years old (I'm guessing this is on your '88) and rubber wasn't meant to last forever. Some poeple spray starting fluid on their hoses to find the leak, as the idle will change when it finds it. Be aware that this can also cause your gaskets to start leaking if you spray it too often, too much on your intake and the components bolted to it, which only complicates the matter.
Seems odd that pushing on your fuel rail would make a difference as there are no vac lines attached to it or anything.
My advice is to keep looking for it, you'll find it eventually.
Old Sep 5, 2002 | 02:23 PM
Spot's Avatar
Re: Vaccum leak?
try replacing the o-rings on the injectors. there are 2 on each injector, one large, one small.
small one just slips over the end where it goes into the lower intake. the larger one is held on with a snap ring. remove snap ring, remove old o-ring, install new one, install ring and you're done. I just did them on one of my cars. Beck/Arnley part number 158-0022 has 4 of each o-ring in it so you'd need 2 of those (and you'd have a coupla leftovers).
Old Sep 5, 2002 | 02:36 PM
dkrzan's Avatar
Re: Vaccum leak?
just a question, but why did u replace the regulator?
d33zdrama
14
Mar 3, 2012 05:15 PM
MIBPreacher
Apr 25, 2006 03:12 PM
fast eddie
Apr 17, 2005 10:12 PM
myxp
Feb 20, 2005 04:36 PM
austin
Aug 19, 2002 06:34 PM
