Terrible Vibration at all speed, all rpms, all gears
Old Jan 1, 2012 | 09:19 PM
yk105's Avatar
Alrighty, so here we go. My Z is a 88 2+2 5 speed. I recently did a burnout one of many since ive had the car for a year. After my burnout i noticed that I was getting a really bad vibration but I can't pin point it, it shakes the whole car very bad yet the steering wheel doesn't shake nor does the car drift either left or right. I am very confused, I just noticed that my wheel bearings in the passenger side front wheel need to be replaced and that the sway bar end link bushing is like nonexistent at this current time, could this cause such a noisy and vicious vibration? It happens through all gears all speeds and all rpms and isnt as noticeable when i accelerate or am cruising but the second my foot comes off that gas completely, my car shakes like no other. O and i was experimenting with this but i noticed that as long as the car is in gear and i am just even lightly touching the gas the vibrations are very minimal compared to any other time. could this be a combo of the wheel bearings and bad bushing? driveshaft? tranny? any help would be appreciated, bearings and bushing will be replaced very soon. Thanks
update: I also have had wheels balanced and rotated a few days ago and still no change in behavior
Old Jan 1, 2012 | 11:57 PM
Check the ujoints in the driveshaft and check the diff mounts.
Old Jan 1, 2012 | 11:59 PM
yk105's Avatar
How will i know whether or not they are bad?
Old Jan 2, 2012 | 06:15 PM
noboosts130's Avatar
Lurker
Also check for a separated tire on the rear.
Old Jan 2, 2012 | 06:20 PM
yk105's Avatar
Whats a Separated tire?? Wouldn't I have noticed that when i balanced and rotated the tires?
Old Jan 2, 2012 | 06:40 PM
Lurker
Tires are made of layers of steel bands and the bands can "separate" from each other. It looks like an egg in your tread. Did you balance and rotate after your burnout?
Old Jan 3, 2012 | 03:49 PM
yk105's Avatar
Yes I did a few days after
Old Jan 3, 2012 | 04:02 PM
Lurker
Then its probably not in your tires. It'll probably be a mount or axle. I mis-read your first post. I thought you rotated before the burnout.
Trex
Dec 12, 2011 04:06 PM
702/808 Z32
Mar 13, 2011 04:35 PM
3riCJbOi
Jun 10, 2010 09:20 PM
90NA300ZX
Oct 22, 2006 12:12 PM
92fairladyz
May 29, 2006 08:14 PM
