Temp guage out
Old Jun 1, 2001 | 05:19 PM
Spot's Avatar
Re: Temp guage out
The power supply can cause portions of the dash to go out. When the one in my '86 started going, the first thing to begin flickering and then go out was the tripmeter section. I think it just depends on which solder connections crack first.
See barkly's posts regarding "Digital Dash" for info on repairing it. Yours will be a bit different, but the connections are in the same location (just not as many of them).
Old Jun 3, 2001 | 12:53 AM
Spot's Avatar
Re: Temp guage out
resolder the pin connections where they go thru the circuitboard inside the power supply - if that's the connection you're saying you need to wiggle to make work.
Old Jun 3, 2001 | 11:50 AM
Ghostz's Avatar
Well, maybe one more
From: Far away, locked up from anything interesting, almost in the dead center of the US
Re: Temp guage out
I had my dash go out and it was exactly like you describe, wiggle the plug and it would work. I did have the power supply resoldered, but that didn't fix the problem, then I had plastic spacers placed in between the plug and the supply, and it worked just fine...
Ghost
Old Jun 3, 2001 | 02:36 PM
Spot's Avatar
Re: Temp guage out
hrm, maybe clean the pins and bend them slightly so they always put a little pressure against the connector?
Old Jun 3, 2001 | 08:19 PM
Spot's Avatar
Re: Temp guage out
check radio shack or some similar electronics type place. there's a spray stuff out there, i think made by CRC and called "electric parts cleaner".
Old Jun 4, 2001 | 05:18 PM
Spot's Avatar
Re: Temp guage out
The fuel sending unit is in the middle of the rear of the car. Unplug the 2 connectors under the carpet back there - there should be a blue one and a white one that both go down thru the access cover. Lift the rear hatch mat and foam stuff, and take off the litle cover with two screws in it (this is the same one with the wires going thru it). Then unbolt the six bolts that hold the other top on then you'll see a whitish plastic thing. Use a pair of pliers to grip the thing and pull straight up. I used two pairs of pliers on mine to pull up on it and it came right out.
here's a snip from some archived info that I found...
1) No smoking! Do this in an open area.
2) Open fuel filler cap to vent gas fumes
3) Do try cleaning the unit first. Extremely easy.
First take a cotton ball and some rubbing alcohol.
Next use a pink rubber eraser on the dry plate. Be
very easy with the eraser. This should give you a very
clean contact for the float.
4) Use a pair of pliers to pull the unit out of the tank,
and replace the check door while your cleaning your
sensor(to keep any junk from falling in).
Unless your float is taking in gas your old sensor should
still work with just a little maintenance.
Old Jun 4, 2001 | 06:09 PM
Ghostz's Avatar
Re: Temp guage out
Doesn't matter now, that car is thrashed. Good suggestion though...
Ghost
drummer69
Jan 17, 2006 07:53 AM
NitZud
Mar 6, 2005 08:23 AM
hjsouders
Sep 19, 2002 07:11 AM
tyco1983
Sep 12, 2002 10:14 AM
tyco1983
Sep 11, 2002 11:26 PM
