Stumble Problems
Old 12-10-2012, 03:42 PM
lostsoul71's Avatar
Question Stumble Problems
Need Help any ideas welcome and Thanks ahead of time! Ok I have a 1987 300 zx non turbo, v-6, 5 speed. New oil pump, timing belt, plugs and wires cap button, new head gaskets worked heads intake upper and lower etc. Ok here is the problem it stumbles between 1400 and 2500 near to the point of shutting off. Acts like (A) lack of fuel or and (B) lack of air. Cleaned mass air flow sensor, Checked Belt timing, Checked distributor timing, set at 20 before top dead center, Checked idle set at 700 rpm, Replaced all Vacuum lines, Checked to make sure no vacuum leaks, has 35-45 p.s.i. fuel pressure. Has good exhaust pressure, will idle and rev without stumble but under load as driving stumbles.
lostsoul71 is offline
mcge8241
06-18-2019 02:47 PM
Montanazx
05-26-2013 10:42 AM
CWHammer
09-02-2011 07:30 AM
duowing
09-30-2006 08:26 AM
Vancouver300z
01-17-2006 05:54 PM
Quick Reply: Stumble Problems
